    rpt
    rpt is offline
    Reputation: rpt's Avatar
    New question here. Marta 180 IS front caliper to Post Mount Fork
    The 180 Marta I have is the one with the long leg.
    Is there a mounting bracket that would allow this to fit a post mount and use the same 180 disc?
    Tried the Magura forum and got a no - but they're pretty cautious and only recommend Magura or the original frame manufacturer.
    Reputation: Joules's Avatar
    not that I've seen. Had the same problem, putting an IS caliper on a PM fork requires going up 20mm in rotor diameter.
    Sorry.
    rpt
    rpt is offline
    thanks Joules
    ok so would need to go to a 200 disc, except magura only do a 203. anyone know of any other discs that would work?
    203 would work
    I was running the same setup on my old bike, except louise brakes, but they where a 180 IS caliper with an A2Z adapter and a 203mm rotor.
