Results 1 to 2 of 2
    Magura Us#? Possible Leak
    can anyone pass on a US contact number( magura), couldnt find it on the site unless it was overlooked. sent them a e-mail regarding a possible defective set of 03 louise fr brakes.( no answer back)
    from day one out of the box they always had a mushy lever action, had to pump the lever to achieve proper pressure. we bleed the rear didnt touch the front and still exactly the same as front. bleed them( rear) 2 more times and same situation. the lbs thinks there is a pin hole or bad o ring in the levers/reservoir.
    or is this the norm for the brakes? they sure are mushy compared to a friends julie brakes.
    Reputation: The Squeaky Wheel's Avatar
    They need to bled. Properly. Shouldn't be mushy.
    From the Magura website: 800.448.3876
    Check out the Magura Cult page if not done so already:
  1. Magura Marta: Post to IS mount?
    By CulBaire in forum Brake Time
    Last Post: 05-26-2004, 07:02 PM
  2. Shimano mineral oil in Magura HS33s?
    By AndyC in forum Brake Time
    Last Post: 05-14-2004, 01:15 AM
  3. Turner 5 Spot & Magura Air Pro Rear Shock?
    By Dirk (UK) in forum Turner
    Last Post: 03-26-2004, 12:03 PM
  4. magura louise FR leverl feel question
    By ToddM in forum Brake Time
    Last Post: 03-12-2004, 09:00 AM
  5. Need help bleeding my Magura Marta SLs
    By AnoBlur in forum Brake Time
    Last Post: 02-29-2004, 07:31 PM
