Results 1 to 8 of 8
    Reputation: Alexgonzalezmi's Avatar
    Magura Mt8 on Stumpjumper HT
    I am buying a set of MT8's for my Stumpjumper 29er HT. It's a 2012. Am I going to need a QM 12 IS adapter for these?
    Dec 2005
    MT8s are post mount so they should bolt onto the frame with a QM 6 post adapter-for a 160 mm rear rotor. The Qm 12 post mount I used for the post mount fork-Reba RL-with a 180mm rotor
    So if I do both rotors in 160 should I get 2 QM 6 adapters? I also have a Reba RL fork.
    MTBR Member
    Reputation: ncfisherman's Avatar
    Quote Originally Posted by Alexgonzalezmi View Post
    If you want to run 160mm rotor up front and you have a post mount front fork, the caliper will bolt directly to the fork.
    If you have an IS rear mount on your frame and you want to run a 160mm rotor, you would need the QM-12 adapter for the rear. If you have a post mount rear, the caliper will bolt directly to the frame.
    The QM-6 adapter is for running a 180mm rotor on a post mount front fork.
    Perfect, I guess I don't need anything then. Thanks!
    Binned
    Nov 2008
    Quote Originally Posted by ncfisherman View Post
    If I did my homework/research properly, the 2012 SJ HT 29er frames (carbon and M5 alloy) have rear PM for 140mm rotors. Therefore, you will need an adapter to use a 160mm rotor on the rear brake...
    My bike came with 160mm rotors but there are spacers under the calipers.
    Mar 2012
    How are these brakes shaping up for you? I have a stumpjumper HT Evo m5 alloy. I want to dump the avids and get a longer term (non-noisy) solution. Any feedback is appreciated!
  1. Magura MT8 fail
    By dirtyjack in forum Brake Time
    Last Post: 01-26-2012, 10:04 AM
  2. Paid Spam: XL Stumpjumper FSR Expert EVO
    By trailwerks in forum Specialized
    Last Post: 01-22-2012, 08:23 PM
  3. Racing XC on Stumpjumper 29er FSR
    By will2007 in forum Specialized
    Last Post: 01-19-2012, 02:25 PM
  4. Stolen: Specialized Stumpjumper Comp 29er (Test Bike)
    By M3ichael in forum California - Norcal
    Last Post: 01-17-2012, 05:55 PM
  5. Stumpjumper 29er Sizing. Help Needed?
    By supros88 in forum Specialized
    Last Post: 01-16-2012, 06:00 PM
