Results 1 to 9 of 9
    RIDE...
    Reputation: MarcoL's Avatar
    Magura MT8 Leaking
    does it have solution or just replace the hose?
    thanks
    Reputation: 006_007's Avatar
    I am thinking the hose needs to be replaced - however contact magura directly as their warranty is VERY good and I am willing to bet they will hook you up.
    Reputation: dirtyjack's Avatar
    Magura warranty's against leakage for 5 years.
    Did you first check to ensure that the banjo bolt is snug?
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    RIDE...
    Quote Originally Posted by dirtyjack View Post
    No I have not, Which bolt?
    nvphatty
    Guest
    Quote Originally Posted by MarcoL View Post
    its the bolt that afixes the banjo/line to the caliper and believe it uses a torx bit to remove/tighten.
    Reputation: cort's Avatar
    Quote Originally Posted by nvphatty View Post
    Additionally....
    Since your already going to need a brake bleed. Take the line off the caliper and check the condition of the two o-rings ( crush washers?) inside the banjo. This could certainly be the source of your leak. New o-rings will cost you barely nothing.
    RIDE...
    Will do, i will receive a hose replacement on moday, thanks
    None
    All ok now
    RIDE...
    Easy, use swiss stop, thats the only brake pad I use in my 4 mtb, excellent stopping power, no noise, last longer.
