Results 1 to 5 of 5
    Magura Martas, opinions?
    Hey, I have a set of 2004 Hayes HFX 9 hydros on my hollowpoint expert, which I would like to replace. I read in a magazine, and maguras site, that the magura martas are 40 grams LIGHTER then an XT V-brake? If this is true, Im going to get rid of my hayes to shed some weight, also, the magura marta SL is about 10 grams lighter then the reg magura martas, any performance difference? How do these brakes compare to my HFX 9's? I presume alot better, but just want some opinions.
    You will save around 160 to 170 grams if you make the swap to the Marta. IMO, the Marta SL's are not worth the diff in price (and I'm a huge fan of carbon). Besides, if you broke the SL carbon lever in a fall, plan on $bending$over$. The Hayes Plus is also VERY nice, I especially like their levers...but they will be heavier than the plain Marta. The Hayes Plus weigh about the same as the Hope Mini Mono.
    I too have been debating the Marta, Mini-Mono & Hayes Plus swap...but I'm coming from a light V-brake setup so I'll be adding weight no matter what I do
    I say base your decision on the company (service).
    Daniel the Dog
    I'd owed Hayes and Magura's...I'll take Hayes!
    Quote Originally Posted by Domdil
    However, the Hayes are heavier. I just like the rock solid feeling of the Hayes. The Magura's were a pain in the tail with those shims. However, I admit, the Magura's did modulate better then the Hayes with sintered pads. I would keep what you are riding.
    One benefit, besides weight, Magura has is great customer service. Excellent.
    Jaybo
    Hey, im going to be buying a set, how do I know if the hose will be long enough? or do they give you ample hose and you have to get a shop to cut,bleed and install?
    simply me
    Reputation: bostonkiwi's Avatar
    It will be... unless you run a 9 inch fork on an XXXL frame.
    yes, usually a bit long.
    No! do it yourself...
  1. EBC Gold and Marta's
    By skinl19 in forum Brake Time
    Last Post: 03-26-2004, 01:45 PM
  2. Turner 5 Spot & Magura Air Pro Rear Shock?
    By Dirk (UK) in forum Turner
    Last Post: 03-26-2004, 12:03 PM
  3. Magura Marta's with SRAM X.9 trigger shifters
    By MINImtnbiker in forum Brake Time
    Last Post: 03-23-2004, 03:24 PM
  4. Add Magura and Speedplay to my "great support" list.
    By DirtDad in forum Weight Weenies
    Last Post: 03-09-2004, 04:58 PM
  5. can i use shimano adaptors with martas........
    By maynard in forum Brake Time
    Last Post: 01-15-2004, 04:36 PM
