Results 1 to 5 of 5
    Reputation: monty797's Avatar
    Magura Marta setup question
    This is probably a dumb question, but we're all entitled to one every now and then!
    I have a set of magura martas that I am running on a Fox Vanilla 36 RC2 with IS mounts.
    Recently I purchased a new set of wheels, Hope Pro II's laced to Mavic 819's.
    With my current setup I'd like to run a little bigger front rotor, a 180 to be exact, mainly because I already have the rotor.
    I have a question about the adapter. I have a Shimano 180m adapter already for IS mounts to convert to a 180 rotor. Will that adapter work for me or do I have to buy a Magura one? The model of shimano adapter is SM-MA-F180S/S.
    Since I already had this one, I figured I'd try to give it a shot, and it seems to be fine, though it holds the caliper in a different position than normal which isnt a big deal I'd guess.
    Or do I have to go find a 51mm to 51mm 180 adapter from Magura?
    Thanks for the help!
    Meh.
    Reputation: XSL_WiLL's Avatar
    As long as the pads are making proper contact and the rotor isn't hitting the caliper, it should be just fine.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    eBay has the 160mm-to-180mm conversion IS adapter, and OEM Galfer rotor. Click link below:
    http://cgi.ebay.com/MAGURA-MARTA-SL-...lenotsupported
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Quote Originally Posted by Zachariah
    Thanks for the link, but I already have the adapter. My question wasn't where can I get an adapter, but if what I had worked.
    Thanks though.
    Seems to be fine as far as contact and fit goes. There is a little slight rotor drag on the pads but I can probably adjust that out with some tiny shims.
