    Magura Marta Problem, sticky lever / piston
    My front brake, a Marta, has a problem. I pull the lever in and it stays there. It doesn't pop back out like its supposed to. This causes the pads to drag on the rotor but when I push it back out the pistons retract and all is good again. Tonight I pulled the pads, pushed the pistons out and cleaned around them with some Magura Blood, pushed them in and pumped them back out a few times. Then I bled the brake thinking maybe there was some air or something. After I got everything back together I still have the same problem. Is there something in the lever assembly I can check or fix to cure this problem?
    Let go lightly
    Reputation: CruzSS's Avatar
    Sticky piston on my Marta's
    I was just about to post a similar problem. One of the pistons on the caliper sticks leading to drag on the rotor after I use the brakes. Magura sent some suggestions on fixing this that involved pumping the brake lever to extend the sticky piston then pushing it back in. This alleviates the problem for a SHORT period of time but doesn't fix it. I have another email to Magura but no response yet. If anyone has a fix to the sticky caliper piston problem please help. I have a 24 hour event this weekend and don't need any friction!!
    Thanks,
    Alex
    My wifes had the same problem.
    Quote Originally Posted by Burger
    Turned out it was gunk in the lever blade pivot. I shot a bit of WD-40 in there and it was instantly better.
    It's been fine for the last 4-5 months after doing that.
    Dave
    awesome!!!
    I just sprayed some WD-40 on that pivot and it instantly worked. Lever returns and no more rubbing. Great, thanks
    Quote Originally Posted by MightySchmoePong
    Dave
  1. Magura Marta SL lever problem
    By mihurka in forum Brake Time
    Last Post: 08-17-2008, 08:33 AM
  2. marta - sticky lever anyone?
    By obaby in forum Brake Time
    Last Post: 03-03-2005, 07:57 PM
  3. Magura Marta lever (and hose) wanted
    By Juan Solo in forum Brake Time
    Last Post: 09-10-2004, 05:19 AM
  4. Quick breakin technique for sticky Marta pistons?
    By Gnarlygig in forum Brake Time
    Last Post: 06-25-2004, 10:09 AM
  5. Marta piston problem, or design?
    Last Post: 06-17-2004, 12:24 PM
