Results 1 to 3 of 3
    Magura Louise Pad same as Louise FR Pad?
    do the 03's use the same pads or do the Louise Fr use different ones?
    thanks
    Same pads.
    The only diff is the pad compound. They make Type 3.1 Performance and Type 3.2 Endurance.
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    yes...
    Pads are the same and can be had in either the performance or endurance compound.
    I've used both. The performance pad is a bit grippier but not by much and the endurance doesn't squeal as loudly when wet.
