Meh.
It's a Louise FR.
The legs are different because front and rear calipers are different. A 160mm rear caliper used on the front would have to use a 180mm rotor.
weak
Are your brakes new?If so the front may not be bedded in yet.So far all my Maggies have oddly bedded in at different rates.Some after a few hard stops,and my last front FR took for ever.But now I can easily lock up the front with 1 finger.Other wise the front rotor/pads are contaminated or you need to bleed them or both.
Swap the pads between the front and rear calipers and see if that makes a difference. If so, your pads are the problem.
- You may not post replies
- You may not edit your posts
Forum Rules
