Results 1 to 2 of 2
    magura HS33 questions
    Hi
    will the new HS33 EVO 2 brakes fit on the back of my santa cruz heckler? I only have V brake mounts but i was wondering if the Brake and all its hardware would fit ?
    What is EVO 2? is it a v brake mounting system?
    kind regards
    kev
    Former Bike Wrench
    Those are designed to bolt up on standard canti/v-brake studs. I don't know about the EVO 2 version, but the old HS33's were awesome...as good as disc brakes in most conditions (just heavy). The had so much power that you often needed the brake arch because they pushed the stays out so much.
