Results 1 to 5 of 5
    Reputation: bigdrunk's Avatar
    New question here. Magura FR Line Cutting - Did I blow it
    I was a few hours (and a few beers) into my bike build. I went to cut my Magura FR's brake lines and followed directions very well, except for one thing. On the first line I cut, I did not push in the brake pads. Recognizing my mistake, I did push in the pads on the other brake before I cut. Now, the lever on the brake that did not have the pads pushed in feels a little softer than the other. The lever does not come close to touching the bars or anything like that, but is definately softer than the other. Do I have to bleed to get an identical feel? Please advise.
    Reputation: magpie's Avatar
    Quote Originally Posted by bigdrunk
    If the one that feels slightly softer is the rear then that's normal (more brakeline = more volume for expansion when the lever is squeezed) but if it,s alot softer, then rebleed if in doubt, rebleed.
    Dave
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    zip tie the lever to the bar for a couple of hours.
    It may push any left over air to the master cylinder.
    gfy
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Should be OK...
    Since the brake is new & the reservoir was full you sholdn't have any problems.
    Had the pads been worn then you'd likely be looking at a bleed.
    My rear Louise FR is slightly softer than the front.
    They were that way from the beginning, and they stayed that way after I cut the lines.
    LL
  1. Trade-offs in anti-squat suspension theory
    By derby in forum Bike and Frame discussion
    Last Post: 05-24-2010, 03:46 PM
  2. magura louise FR leverl feel question
    By ToddM in forum Brake Time
    Last Post: 03-12-2004, 09:00 AM
  3. Magura Louise FR adaptor question
    By SuperBad in forum Brake Time
    Last Post: 03-09-2004, 02:38 PM
  4. Magura Louise FR Line Cutting Question
    By toonces in forum Brake Time
    Last Post: 03-08-2004, 08:03 AM
  5. Magura Louise Pad same as Louise FR Pad?
    By staz in forum Brake Time
    Last Post: 03-06-2004, 08:31 AM
