Results 1 to 2 of 2
    rack admirer
    Reputation: Mr Magoo's Avatar
    Magura Fluid turns metalic grey
    The patient is a '00 louise that was last bled in 2002. Performance got mushy unless I pumpoed them first so I figured it was finally time. When I opened up the resevoirs, the standing fliud looked like the oil coming out of my fork; silvery dark. I pumped in the good stuff thru the calipers, but the current pattern in the resevior did not push the bad color out. Instead, the fresh stuff started coming over the top. I didn't think to siphon off the top.
    My question is Is this contamination coming into the resevior with out there being a leak or coming up from the moving parts in the levers or the pistons?
    MCM # 57
    Reputation: lebikerboy's Avatar
    Jan 2005
    The same thing happened with my HS 33s. Keep flushing the system until the fluid coming out is clear. It may take up to three bleeds.
    Quote Originally Posted by Mr Magoo
  1. Magura brake fluid question?
    By texheckler in forum Downhill - Freeride
    Last Post: 11-03-2016, 12:55 PM
  2. Bled with wrong brake fluid. Now what?
    By Freshies in forum Brake Time
    Last Post: 08-27-2004, 12:30 PM
  3. brake fluids?
    By r1Gel in forum Brake Time
    Last Post: 08-10-2004, 06:39 AM
  4. Magura fluid question?
    By texheckler in forum Brake Time
    Last Post: 07-26-2004, 10:13 AM
  5. Hydro fluid - only use from new, unopened bottle
    By frank n. beans in forum Brake Time
    Last Post: 04-05-2004, 10:04 PM
