Results 1 to 3 of 3
    M785 bleeding with Shimano Funnel. HELP!
    As I was trying to bleed my M785 XT brakes, I realized that my Shimano funnel does not screw on to the cylinder bleed port. The hole is too small for the bleed funnel. The manual says to screw on the funnel to the bleed port, but no luck.
    I know there is a white and yellow Shimano bleed funnel, both labeled as SM-DISC. Anyone know if white and yellow are different thread size?
    n/m I figured it out.
    Reputation: Slurry's Avatar
    Dec 2008
    funnel goes on lever.
