Results 1 to 8 of 8
    Nov 2007
    Louise BAT calipers with Marta SL rotors?
    Is this possible? Any of you guys have experience with this? Competitivecyclist said that this is not recommended. They recommend using the Magura SL and NOT the Marta SL rotors. I really want the look of the Marta SL discs. Help!
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    The problem is that the brake pads from Louise and Marta brakes are different widths, so the swept area of the rotor is different for each pad. The Louise has a larger swept area so when used with a Marta rotor, the pad scrapes a fair distance down the rotor spokes. It doesn't take long for the rotor spokes to get thin and this could cause a failure in the rotor.
    My video techniques can be found in this thread.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Try Avid
    Quote Originally Posted by crudscraper
    The ultra-rare Avid Clean Sweep Serpentine wavy rotors look/work just like the Marta SL/Galfer wave rotors, and should work well with your Louise brakes. Here is where to find them:
    http://cgi.ebay.com/AVID-160mm-Serpe...lenotsupported
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    As stated above, the Marta SL will not do well with the Louise calipers.
    The Magura SL drilled rotors are better for heat and durability anyway. The VentiDisc rotors are kind of heavy, but are pretty............
    Lead by my Lefty............... right down the trail, no brakes.
    Nov 2007
    Venti it is
    I might as well use ventidiscs as I prefer magura rotors on magura calipers. Kinda pretty too. Thanks.
    Nov 2007
    same pad for the marta as the louise for 2009
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    I think that the Louise OEM come with the SL rotors. I like the Ventis, they have worked pretty good so far.
    "El Whatever"
    Reputation: Warp's Avatar
    Quote Originally Posted by 29ERCAT
    Yeah, but I think the marta was the redesigned one, not the Louise. The Louise remains as the same brake it is since 2004 or so with very slight upgrades.
    Check my Site
