Results 1 to 3 of 3
    Reputation: OffRoadRoadie's Avatar
    Lost bolt that holds disc brake pads!
    The bolt that hold the pads (04 XTR discs) in place came out during a ride and before I knew it the pads popped out too, never did find the pads (every fir cone on the trail looks just like a disc pads). The carter pin (correct name?) that holds the bolt is a shitty design, is there a c-chip that would fit, loc-tight, safety wire? Recommandations?
    Do the metal XTR pads squeal more than the resin pads during extented downhill braking? Is the resin/metal pad combo a good set-up for dry summer riding?
    Reputation: Goliath_2's Avatar
    Those pins suck
    ...same thing happened to me. try using a small zip tie at the end of the in once it's fully threaded into the caliper. make sure the zip tie is VERY tight (use a fourth hand tool). it worked for me.
    Thanks, great idea!
    Are you using the metal/resin brake pad combo?
  1. disc brake pads are rubbing on the rotor
    By neversumme144 in forum Brake Time
    Last Post: 04-29-2004, 08:39 AM
  2. how do you get the disc brake pads put
    Last Post: 04-25-2004, 07:43 PM
  3. Stan's disc brake rotors and pads
    By thegood in forum Brake Time
    Last Post: 04-16-2004, 07:32 PM
  4. Which new disc brake pads?
    By pimpbot in forum Brake Time
    Last Post: 03-29-2004, 09:20 AM
