Results 1 to 7 of 7
    Reputation: in the trees's Avatar
    Mar 2005
    Loose Formula Pads
    The pads in my RX calipers "jiggle" slightly on the pad pin. This looseness feels the same on both the front and rear calipers. When i apply light lever pressure, I can still feel them move when i rock the bike back and forth (almost like a loose headset feel). This goes away with firm lever pressue. Is this typical? I haven't had a set of Formulas in a while and I don't remember this occurring on my old K18s. And I haven't had the chance to ride the bike to get a sense of what it feels like while riding.
    Plays with tools
    Reputation: customfab's Avatar
    It's common with more than just Formula's
    Jun 2012
    My formula Rx's do that too. Awesome brake, love mine.
    When you replace the pads, see which spring has more tension. I have reused old springs because the one provided with the new set of pads either didn't fit properly or didn't have enough tension to push the pads into the piston
    Mar 2005
    Thanks, guys! I was at a LBS today and they had a bike that experienced this as well. I just wanted to check. Does this result in any excessive noise on the trail -either rattling or warbling?
    Dec 2011
    I've got a couple of sets of RO's and The Ones, all have this same movement and slight 'rattle' in the pads. I only notice when rocking the bike stationary, whilst riding, no noise or extra movement noticed. I also tried bending the return spring to give it more tension, but I didn't notice any difference.
    The only time I hear noise from the brakes is when riding in really dusty areas, usually the rear brake is affected and makes a 'warbling' noise. The rattling is probably there but I can't hear it over general bike noise (cables moving, tires, chain slap...).
    Jun 2012
    The movement and sound that you feel and hear while rocking the bike back and forth, will be non existent when using the brakes.
    Under braking it is a uni directional force and therefore you will not get the same sounds.
  1. Formula RX brake pads....
    By trap121 in forum All Mountain
    Last Post: 02-19-2013, 08:06 PM
  2. Formula pads
    By Smilerz in forum Bike and Frame discussion
    Last Post: 09-02-2012, 11:04 AM
  3. Formula The One - brake pads fell out
    By wizard604 in forum Brake Time
    Last Post: 07-27-2012, 09:56 PM
  4. Formula R1 pads work on Oro k 24?
    By Roger___ in forum Brake Time
    Last Post: 06-22-2011, 01:17 PM
  5. Formula brake pads wearing out fast!!!
    By groovastic in forum Brake Time
    Last Post: 04-06-2011, 04:14 AM
