Results 1 to 22 of 22
    Missouri sucks...
    Looking for Formula R1 "Super Batman" brake set
    Anyone know where to get them?
    You mean the all black/carbon lever set?
    there is pairs on ebay.it
    Reputation: BrokenBones's Avatar
    Feb 2005
    e-Bay seller in Italy
    Contact e-Bay seller clood69 in Italy. He puts them up (other colors as well) for sale fairly frequently. There's 1 set listed right now. I wanted a set for a recent build, but none were available at the time, so I never bought from him. I can't comment on his reliability/ethics, etc. Other buyers seem to have had great success though.
    'Bones
    Missouri sucks...
    Thanks guys!
    Mar 2012
    Anyone seen these for sale recently? I am looking for a set...
    bt
    bt is offline
    Nov 2007
    worst brakes I ever had
    Mar 2012
    why is that? I have heard they are finicky...and where did you get yours?
    bt
    bt is offline
    Nov 2007
    serious let down
    Quote Originally Posted by bt View Post
    serious let down
    Only trolls diss and give no info
    bt
    bt is offline
    Nov 2007
    Quote Originally Posted by AlexRandall View Post
    not interested in an e-pissing match
    Mar 2012
    No pissing match needed, i'm looking for honest expansion to why they are a let down. I am looking at getting these or hope X2s. Anyone else care to chime in?
    Reputation: mazspeed's Avatar
    Get the hope x2. It's a better brake. I have seen many formula issues in regards to, air, bleeding issues, lack of power over time, and a general lack of quality.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I have x2's and can say that they are great in the right application. For XC? YES. For AM or more? NO.
    Reputation: GuruAtma's Avatar
    I've got those formulas. Super light, stop great, good modulation etc. Pad clearance is very very low, so it seems the pads are always hitting the rotor at least a little. Putting in new pads makes it worse. The LBS can make it slightly better, but not perfect. It's more of an annoyance than something that actually affects the ride.
    功夫大师喜欢骑着他的自行车在山上。
    DTP
    DTP is offline
    Feb 2012
    i just installed a formula 1 break set (levers say formula 1 on them however the calipers it says RX). they are squeaky and they seem to lack power compared to my shimano xt deore.
    i will have my LBS take a closer look at it.
    any suggestions on the squeak and power?
    If they are absolutely brand new then you'll need to bed the pads into the rotors, and also bed the rotors in themselves. This usually takes the best part of 1 ride.
    The squeak sounds like a misaligned pad/rotor. It also could be that during bed-in that too much heat was generated and the pads could be glazed.
    To the OP:
    As bt still hasn't been bothered to explain his 'mythical' bad experience of R1's, I'll share some of my experience:
    Got my first set about 2 years ago. Had come off Hope mono mini X2 (nice modulation but poor overall power) Avid Elixir varieties (good power for the ones I had, but much heavier) & new XX brakes (not up to elixir power, but light as R1)
    The R1's were straightaway VERY powerful. I bought some Ashima rotors with not much rotor material to try and tame the power, and went 4" on the rear too.
    They have tight tolerance thats for sure. I got some white powdercoated ones, where they had gone overboard on the coat thickness. I had to sand them down a bit to get the rotor to not rub the mounting arms. They also struggle with the rivets on 2-piece rotors like Hope.
    Once I got them setup, which was not that bad a job really, they quickly became set and forget. They seem to avoid the sticky piston issues I have found with XTR and some elixirs. If the pistons do end up too far out, then they retract quite readily.
    Those brakes are still on my #1 race dually, and have travelled overseas 3 times for various events I've done. Ive never yet had a lightweight part last so long, and be just as good as it was when first installed. I've bought a second pair which is about to get installed on the 29er hardtail I'm about to build up.
    bt
    bt is offline
    Nov 2007
    I'm not sure what your idea of a forum is, but for must of us it is the exchange of opinions, information and technical know-how.
    You fail on all counts.
    Either contribute to the threads you post in or bugger off
    bt
    bt is offline
    Nov 2007
    my opinion is r1's suck.
    But as you've given no basis for this you fail.
    And you still refuse to give any info.
    You've been asked many times
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    I got some used R1's off Ebay for super cheap, they are my first discs, but they seem very strong, I got them mainly due to the weight. Back had centering problems and dragged the piston on the caliber as a result, I had LbS replace the pistons seals, which may have been overkill but got the job done.
    Agreed they are finicky and drag a little, but i'm not sure this is exclusively due to tight clearance as others have said, I think they are prone to slight centering issues, so whenever I remount, I put a piece of paper or card stock on the dragging side, hold down the lever, and tighten the bolts. This gets it down to no it virtually no dragging. I am pretty sure that's a common problem (not just R1's) because I got it off a long Avid troubleshooting thread.
  1. Replies: 1
    Last Post: 02-29-2016, 12:15 PM
  2. Replies: 18
    Last Post: 07-23-2009, 11:33 PM
  3. "Kliane" "Klein" "Quasi Moto" "Paul"
    By stan4bikes in forum Vintage, Retro, Classic
    Last Post: 08-20-2007, 03:36 AM
  4. Maxxis "Ultra-Light" Tubes = "Super-Thin"?
    By allandavid in forum Wheels and Tires
    Last Post: 03-10-2007, 05:23 PM
  5. Replies: 42
    Last Post: 01-24-2006, 09:37 PM
