Results 1 to 7 of 7
    rolling in the greens
    Reputation: vermont's Avatar
    looking for a caliper mount
    for an older hayes G-1 rear caliper with 22mm mounting bolts to accomidate a 180mm rotor on a SC Heckler with IS mounts. Anyone know...i have been looking all over the internet and cannot find one.
    thanks
    Keith Bontrager: "Strong, light, cheap pick any two."
    "Something strong and light ain't gonna be cheap. -That's what I call bling.
    And cheap and strong ain't gonna be light. -That ain't bling."
    -----locoman
    "That said, I never deal with bike shops for the same reasons. I am a ebay and mail order whore and I don't care" -----yetisurly
    New question here. cant find anything??
    i guess i'm gonna have to buy a new caliper.....bummer
    -----locoman
    Do It Yourself
    Reputation: Homebrew's Avatar
    New caliper and maybe a different brand. Hayes doesn't make adapters for 180mm rotors. But if you get standard post mount caliper, you should be able to use an Avid 185mm adapter for the rear.
    Long Live Long Rides
    185mm Avid RR IS mount
    is what i am using on my other bike works fine pads hit rotor dead center...a
    ll my rear wheels have a 180mm rotor on them....
    i want to be able to change wheels w/o changing rotors.
    thanks for reply
    -----locoman
    Reputation: wyrm's Avatar
    You can still find caliper halves out there for the G1's. I would check Universalcycles.com. That way all you have to do is just buy that and the adapter and not the whole caliper. You will have to rebuild what you have tho, which might take a little wrench science.
    Do It Yourself
    Quote Originally Posted by wyrm
    But that caliper is for a 160 rotor. Since Hayes doesn't support 7" rotors, there are no 22mm mount +20mm adapters.
    used a avid 185 mount
    on my other bike...worked just fine with a 180mm rotor
    this is the setup on the heckler now...
    -----locoman
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Fox 40 caliper mount info
    By misctwo in forum Shocks and Suspension
    Last Post: 01-30-2005, 08:42 AM
  3. Fox 40 caliper mount info
    By misctwo in forum Brake Time
    Last Post: 01-26-2005, 12:31 AM
  4. IS Disc mount - Ugh....
    By Jdub in forum Brake Time
    Last Post: 12-03-2004, 09:40 PM
  5. Replies: 2
    Last Post: 06-08-2004, 04:55 PM
