Results 1 to 11 of 11
Thread: Loctite?
    Loctite?
    Got a new wheel, and I was wondering if I need to put locktight on the bolts that hold the brake rotor on. There was some from the factory but it is necessary or should I just check them often?
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Quote Originally Posted by Flynnster
    Got a new wheel, and I was wondering if I need to put locktight on the bolts........... is necessary or should I just check them often?
    You should do one or the other. I use Loctite. Mine are Torx bit. Seeing how I don't know anybody who carries a T25 Torx bit driver with them on rides I'd rather just set them and forget them.
    Ok, thanks alot.
    Reputation: 006_007's Avatar
    I dont bother using applying new loctite - however I do use this great tool called a torque wrench. It tightens the bolts to manufacture specifications. Fantastic thing is using it I have never stripped a bolt, or had a bolt loosen off (to get my moneys worth out of the torque wrench I periodically use it to check the torques on key areas of the bike)
    And my multi-tool does have a t25 bit in it for on the trail emergencies.
    Well with a no name bike like mine I didn't get any manufatureres specifications or I would use one of my torque wrenches.
    The torque spec is, often times, printed on the rotor. If there's no torque spec printed on your rotor, shoot for 55 in-lbs.
    I think using blue threadlocker on the rotor bolts is a good idea anyway.
    Reputation: Teebird's Avatar
    You gotta figure with that small aluminum hole, the torque will be small. Just go around the rotor tightening each bolt a little at a time like you would a car wheel or a cylinder head. I use Loctite. The blue stuff. DON'T use the red. You'll never get it back off. I ride dirt bikes, and use blue Loctite on almost every bolt and nut on the bike. Mountain bikes see similar type of terrain and vibrations just not the same magnitude.
    2016 Pivot Mach 429 Trail, XT/XTR 1x Build Kit
    Torque Wrench
    [QUOTE=006_007]I dont bother using applying new loctite - however I do use this great tool called a torque wrench. It tightens the bolts to manufacture specifications. Fantastic thing is using it I have never stripped a bolt, or had a bolt loosen off (to get my moneys worth out of the torque wrench I periodically use it to check the torques on key areas of the bike)
    QUOTE]
    +1,000 on the Torque Wrench......
    Lots of info on sites like the Park Tool site with torque settings for bike bolts.
    I had a stem creak..... Bolts felt tight but weren't torqued up correctly. Once torqued up all good.....
    Used the blue stuff, its medium, reds heavy duty right?
    EDR
    Jun 2005
    Si. I use it everywhere. Chainrings, rotor bolts, shock bolts, der. hanger, etc, etc, etc.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Awesome thing about Loctite is that it keeps air and moisture from ever getting in the threads, so they stay nice and clean and never corrode. Perfect for mountain bikes.
    I like turtles
