Results 1 to 6 of 6
    Lockring vs. 6-bolt
    What are the differences? I have a lockring type on my bike. What is lighter, etc.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by eman2005
    Centerlock is a different rotor mounting interface. Basically Shimano designed it and only their rotors use it. I have several Centerlock hubs but use 6-bolt adaptors and standard IS 6-bolt rotors. Works fine. Kind of nice to need to tighten just one thing to mount rotors.
    mtbtires.com
    bi-winning
    Reputation: rkj__'s Avatar
    Shimano centerlock (lock ring style) are so much easier to take on and off... Not that I do that often though.
    Shimano centerlock hubs tend to be lighter than similar 6 bolt hubs
    Dec 1998
    Quote Originally Posted by tilk
    Though the rotors tend to be heavier.
    If you use the 6-bolt adaptors it is basically a wash.
    mtbtires.com
    Reputation: vk45de's Avatar
    shimano would like you to think their setup is lighter, stronger, and easier to remove due to spider. it may be lighter on XTR rotors with the big spider, on models w/ smaller spiders such as XT, it makes a weaker case. i see it just as a compatibility issue introduced by shimano b/c they think life was too simple
