Results 1 to 3 of 3
    Jan 2014
    A little help needed mounting rear p to p adapter for shimano 180 mm rotor
    I got the new rotor and the adapter just a little confused on which direction to mount the adapter. should the larger spacer be on the front or rear post. Thanks! If anyone could post a pic that would really help!
    B A N N E D
    http://techdocs.shimano.com/media/te...9830667774.PDF
    The arrow on the adapter always points in the direction that the wheel/rotor spins when you ride the bike.
    Aside from reading that arrow correctly, the reason you put the cone/cup spacer is to allow bolts to sit straight into the brake mount post even with slight angle introduced by your 60-to-80 mm adapter which changes the angle of the brake caliper in relation to your fork/mount. If you, for example, use these spacers between the post and adapter or caliper, then your bolt would sit directly on angular contact surface of the caliper - that can potentially snap/crack the post by applying perpendicular force to the post.
    So, it's very important to follow the direction in this particular instance.
  1. which Shimano lockring for rotor adapter
    By teachndad in forum 29er Components
    Last Post: 09-06-2012, 12:36 PM
  2. Shimano rotor mounting hardware
    By JonathanGennick in forum Brake Time
    Last Post: 08-12-2012, 12:49 PM
  3. rear rotor adapter on a HD?
    By slideways666 in forum Ibis
    Last Post: 04-26-2012, 09:14 PM
  4. Adapter needed for 160mm rotor in front?
    By fskywalker in forum General Discussion
    Last Post: 04-06-2012, 02:14 PM
  5. Replies: 2
    Last Post: 08-17-2011, 03:22 PM
