Results 1 to 2 of 2
    Light rotor recommendation for Oro Puro?
    I'm in need of rotors for some new Puros that I just got. I was hoping to go with something a bit lighter than the standard Formula Oro rotor (I have one that weighs 125 g. on my scale). I'd like to go with the Hope floating (160mm) rotors because they're light and look good, but it sounds like there have been some compatibility issues. Does anyone know if those will work with the Oro Puros or their adapters? I'm running a Fox Float 32 (140mm) with post mount and the rear is an Ibis Mojo with IS mount. Any other lighter rotor recommendations?
    Also does anyone know if you can run a 140 mm rotor (rear) with these? the adapters that I have are for 180mm front and 160mm rear, does somebody out there make an adapter (PM - IS) for a 140mm rotor?
    agu
    agu is offline
    how about the Formula R1 rotors? Or something from Scrub Components...
