Results 1 to 3 of 3
    Lever Recommendations
    Building up the Smoothie this weekend and looking for lever recommendations. Went with the Avid CPS brakes. I have Love Levers for the vee's and wondering about opinions of the Paul's vs Avid Ultimates. Thanx!!
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    As per usual, please search the forum before posting a similar new thread. Thank you.
    Lever questions for Avid mechs are quite common here.
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    Quote Originally Posted by MTBDad
    I recently switched from old Avid SD2.0's (same as the SD-7's) which were getting sloppy in the pivots to a set of the Avid Ultimate Black Ops. The Ultimates are quite nice with no more lever slop. I like the leverage adjustment with the mech discs. I've got them adjusted about mid-way, and they modulate well. Way pricey, but nice. The bolt torque settings are engraved right on the lever body for a rather industrial look. I've never used the Paul's Love Levers, though lots of folks like them, too. I believe they're less expensive, if that matters.
    Kathy :^)
    Look where you want to go. This is as true in life as it is in mtbiking.
  1. Fox Float RL lockout lever
    By michyeti in forum Shocks and Suspension
    Last Post: 02-14-2012, 06:34 PM
  2. Avid Juicy 7 lever action lost
    By mountaingoatepics in forum Brake Time
    Last Post: 04-07-2005, 07:59 PM
  3. 2002 Louise lever creeping
    By CliftN in forum Brake Time
    Last Post: 06-08-2004, 10:07 AM
  4. Shimano disc lever question
    By indigosky in forum Brake Time
    Last Post: 05-11-2004, 01:24 PM
  5. Replies: 4
    Last Post: 01-22-2004, 12:09 PM
