Results 1 to 2 of 2
    lever reach adjustment stripped on hayes
    Stupid me put too much loc-tite on my always-backing out 2003 hayes mag lever reach adjustment screws. Wait, it gets worse. I stripped the tiny allen heads out.
    Anyone know if I can get it out, and replace it? I'm looking to sell them but don't want to write the ad with, "Reach screws are stripped and in the maximum reach position, so if you have small hands, you're screwed (no pun intended)."
    Reputation: 006_007's Avatar
    Quote Originally Posted by danK
    Sounds like you used the red loctite instead of the blue loctite. You could try using an EZ-out to remove them. available from hardware stores. As for the replacement, I believe the sdjustment screws are integrated into the bladder/internals. The internals are replaceable. The following sites usually have the parts available:
    www.go-ride.com
    www.balleracing.com
    TJ
  1. Hayes Comp lever play - help!
    By MRfire in forum Brake Time
    Last Post: 07-02-2004, 10:27 AM
  2. help with Hayes lever - won't snap back
    By freeriderB in forum Downhill - Freeride
    Last Post: 06-15-2004, 07:41 PM
  3. Hayes lever set screw backs out, help?
    By ibmkidIII in forum Brake Time
    Last Post: 03-30-2004, 09:33 AM
  4. Hayes Mag lever reach adjustement loose?
    By ptolar in forum Brake Time
    Last Post: 03-12-2004, 07:58 AM
  5. New XT levers - reach adjustment?
    By jcw in forum Brake Time
    Last Post: 02-04-2004, 04:02 AM
