Leaky Juicy 7, too juicy!?
I got my Juicy for about 1month & the rear lever kinda stiffen up for no reason, went a a ride, squeeze it alittle & the brakes are back to normal but there's dot 4 leaking from the gap between the reservoir & the cap.
the leaking did not cause any lost of braking power & modulation but rather disturbing.
checked for loose screws on the cap but everything is fine.
what could be the problem? if leaking stops.. is it alright?
got bad
leaking got bad. initially was only the right lever, now it's the left lever...
HELP someone!!!
By Ventanarama in forum Brake Time
Last Post: 05-04-2005, 09:26 PM
By string in forum Brake Time
Last Post: 12-23-2004, 08:22 PM
By danK in forum Brake Time
Last Post: 10-07-2004, 08:51 PM
By martynda in forum Brake Time
Last Post: 09-22-2004, 07:52 AM
By JerryBoneJr in forum Brake Time
Last Post: 05-06-2004, 10:41 AM
- You may not post replies
- You may not edit your posts
Forum Rules
