    Reputation: maynard's Avatar
    leaking resevoir on my martas
    , lost all braking control today (front brake) on my marta front brake, bled the brake, works great but noticed that the top cap of the resevior with the 2 TORX6 bolts has a leaking bolt, i flipped it around and the same bolt kept leaking a small amount of mineral oil everytime a really cranked on the brake lever. any suggestions for a quick fix and where i could get a new top cap for the resevoir, hope i explained my problem well.
    MaY
    No good pic of leaking lever
    magura marta front brake
    Just contact the guys at Magura, they'll probably set you up with...
    Quote Originally Posted by maynard
    MaY
    ...replacement parts if needed. Are you sure the bolts are torqued properly though?
    Yup....
    Quote Originally Posted by Gnarlygig
    There is a 5 year leakproof warranty so no worries... just have your LBS or call them yourself, all will be good.
    Pat T.
  1. EBC Gold and Marta's
    By skinl19 in forum Brake Time
    Last Post: 03-26-2004, 01:45 PM
  2. need help 5th element leaking...
    By markymark7200 in forum Shocks and Suspension
    Last Post: 02-08-2004, 07:13 AM
  3. X3.1 leaking at the spoke hole.
    By happybiker in forum Wheels and Tires
    Last Post: 02-03-2004, 06:38 AM
  4. 2002 fox fork leaking...
    By Satyricon in forum Shocks and Suspension
    Last Post: 01-24-2004, 09:45 AM
  5. can i use shimano adaptors with martas........
    By maynard in forum Brake Time
    Last Post: 01-15-2004, 04:36 PM
