Results 1 to 10 of 10
    Nov 2008
    largest rotor size?
    Hey so I have an Iron Horse Quantum 2, and right now it has Hays mx4's, but i feel like i dont have enough stoping power, and yes I have adjusted the brake pull. Would a larger rotor help? I dont really want to upgrade to hydraulic breaks right now.
    Chris
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    What size rotor and fork do you have??
    I'm feelin lazy.
    Formotion Products
    http://www.formot
    Nov 2008
    I have 160mm rotors and 100mm travel fork, Its a Rock Shox dart 1. would 185mm rotors fit ok? I know i would probably have to get longer bolts for the brake itself.
    I know on my Dart3 the max recommended rotor is 160mm so I'd guess it's the same for yours.
    Former Bike Wrench
    Max rotor size for the Dart is 165mm (to include older Avid Mechanical brakes)
    Suffers From Binge Biking
    Reputation: marsh rider's Avatar
    Yeah 160mm is the largest size you should use on your fork. I ran a 185 on my fork for a while and didn't have any problems (that I noticed) but ended up switching it back anyway.
    If it ain't broke, fix it 'till it is.
    Nov 2008
    what about the rear? could i put 185 for the rear rotor?
    Sure can. Just make sure you get the right adapter.
    Jan 2005
    Go with a 185mm front rotor and leave the rear as a 160mm, you dont need a bigger rear rotor to skid up the trails.
    Formotion Products
    http://www.formot
    Former Bike Wrench
    Assuming the frame has clearance for it...which some don't
    But its pointless to run a 160mm rotor up front and a 185mm rotor in back...70%+ of your braking power is up front.
    Maybe consider some Avid BB7's as a simple upgrade
