Results 1 to 26 of 26
    Larger vs. smaller brake pad surface area ?
    The surface area on my current disc brake pads seems quite small (maybe the size of a nickel) I was looking @ a few other brake sets and they appeared closer to a quarter. What effect does larger or smaller surface area have on brake performance ?
    Old man on a bike
    All other things equal, a bigger pad would increase braking performance just as a larger rotor would. Difference in caliper designs definitely play a role too, though.
    suum quique
    Reputation: RustyIron's Avatar
    Bwahahahahahahahahahahahahaha!
    Don't listen to him, Keen. Changes in the surface area of the pad affect the pressure of the pad upon the rotor, thus the amount of friction. Your question is much more complex than it would seem, and you can't reach any general conclusions from just that one bit of data.
    Old man on a bike
    Quote Originally Posted by RustyIron
    So, don't listen to what, genius? Been baking in the socal sun a bit long?
    suum quique
    Maybe you could elaborate and shed some light on the complexity ?
    Quote Originally Posted by Bikinfoolferlife
    Don't listen to YOU.
    "Bigger pads, larger rotors."
    What does THAT mean?
    'Spose you just tell us about the relationships between area, pressure and friction.
    Bwahahahahahahaha!
    Dummy!
    Quote Originally Posted by keen
    Sorry, Keen. There is insufficient data to reach any meaningful conclusion. But perhaps we can still help. Specifically, what brake components are you considering installing, and what is your desired goal in changing from your current setup?
    I currently run Hayes Mag brakes w/ G1 Calipers. I like the brakes but the calipers are quite dated. The new Hayes Stroker Trail calipers can be used w/ my Mag levers, according to Hayes. The calipers have the same diameter pistons but the Strokers have larger pads.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    You're wrong. All else being equal, you're right that there will be less pressure on the rotor with bigger pads, since the force from the pistons will be spread out over a greater area. However, this doesn't translate to more friction. Friction is proportional to the FORCE applied, not the pressure. So if you run pads made from the same material in the same brakes, power wouldn't change. The smaller pad would wear faster, and would not dissipate heat as well. But that's it.
    If you're going to spout off and call someone out on something, at least make damn sure you're right.
    Old man on a bike
    Bwahahahahahahaha!
    Dummy!
    Heat is a large factor in a disc brake's performance. A larger pad can dissipate heat better, as can a larger rotor (which also has a torque advantage). That's what it means. Go back to your physics class and figure it out...
    suum quique
    Reputation: vk45de's Avatar
    Quote Originally Posted by Hardtails Are Better
    I wouldn't be too sure about that. Why you suppose they put wider tires on sports cars? To not change friction at all?
    Meh.
    Reputation: XSL_WiLL's Avatar
    Quote Originally Posted by vk45de
    The contact area does not change the coefficient of friction. But a larger contact area means just that... more contact... This can help account for uneveness, bumps, etc.
    mbtr member
    Reputation: scottzg's Avatar
    Small pads generate more heat per unit of pad surface, so they use a broader range of operating temperatures. Pads can't be designed to be optimal at all temperatures, but can be designed to be effective at high temps or low temps. Larger pads allow the designer to select a pad that operates more powerfully in a narrower range of temps or have more consistent performance at a wider range of temps.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Actually, this is wrong.
    Quote Originally Posted by wikipedia
    The force of friction is independent of the apparent area of contact. (Amontons' 2nd Law) (Amontons' 2nd Law does not work for elastic, deformable materials. For example, wider tires on cars provide more traction than narrow tires for a given vehicle mass because of surface deformation of the tire)
    Meh.
    Not exactly wrong...
    The force of friction is independent of the apparent area of contact (in an ideal world)... The contact area does not change the coefficient of friction.
    Surface deformation allows for more contact (ie over bumps and uneveness). The actual coefficient of friction is not affected. Wider tires provide more resistance to slippery spots or grit on the road. Race tracks have gravel, dust, rubber beads and oil on them in spots that limit traction. By covering a larger width, the tires can handle small problems like that better.
    Also... your wikipedia excerpt is uncited.
    The reason for wider tires is not that the increased contact area automatically leads to more friction (though there may be some effects that depend on the area indirectly). The design parameter that determines the coefficient of friction between the tires and the track is the something related to the molecular compressibility of the rubber. In other words, "the softer the rubber, the better the friction." However, when you use a softer rubber, you need to make the tires wide enough to give them strength. So, "the softer the tire, the wider it needs to be", to withstand design forces and moments.
    Also, narrower tires will tend to abrade rather than get tacky. Sticky tires have a weak sheer strength. This is compensated for by using wider tires. The larger area is needed to support large tangential forces.
    Friction is resultant on surface irregularities - at least abrasive friction is. It is caused by these irregularities grabbing on each other. The area of the brake pad (and a tire's footprint) is the apparent area only. What Amontons law basically states is that the real contact area is independent of the apparent area for non-deformable objects.
    You're basically explaining how increasing the apparent area of a deformable surface increases actual contact area which in turn affects the coefficient of friction. Is that not changing the coefficient of friction? hint: Force of friction = coefficient X normal force and you're not changing normal force significantly with larger tires.
    Here's a citation:
    http://books.google.com/books?id=HWL...age&q=&f=false
    If you're wondering why I brought this in, it's because we don't live in a perfect world. There is no such thing as a perfectly non-deformable surface, there's no such thing as a perfectly deformable surface, there is no such thing as a perfectly elastic collision, no such thing as a perfectly non-elastic collision, and so on.
    Meh.
    No. I said that it is NOT affecting the coefficient of friction. A given material has a given coefficient.
    Either way... larger tires is a poor example.
    From what I've observed...
    Larger pads with all else being equal:
    Do not affect one stop power
    Wear out slower
    Heat up slower and dissipate heat quicker
    Are sometimes more likely to squeal
    These are my observations mostly on cars but also with bikes. I'm no engineer.
    I think one of the biggest misconceptions is a larger pad will increase one stop power.
    My pads seem to have no problem transferring heat into the BB7 calipers. Maybe the heavier calipers could be a good thing in that way.
    At equal pressure, bigger surface gives greater stopping power IMO... Why give all the manufacturer bigger pads with the stronger brakes? I just imagined, I replace my pad with a nail. Theoretically (acc. to your opinion) no change between a bigger surfaced pad and a pointed nail (minimum surface area)?? It is nonsense, I think...
    If the surface is less, you need more pressing power to reach the same affect to the disc. Just try to hold something with one finger, or more...
    Im not an engineer either...
    Jul 2015
    Well, this is interesting. Having stumbled upon this thread out of curiosity as to an accurate answer on the subject for myself and having wasted my time reading an entire page of not much more than blab I discover that this thread like so many others to be found on the Internet are nothing short of useless, no insult to the author. So many wannabe keyboard tough guys and Einsteins spewing crap at each other irrelevant to the actual topic. I'm quite sure if I were to look elsewhere I could find most likely a simple formula that can result in providing me an answer on the advantages of using a larger brake pad over small, if indeed there are any at all. Grow up and get a life people, stop wasting your own time and that of others. Congratulations to Adept for providing from what I've read, the most interesting and relevant reply.
    PS to all I'm not an active user of this forum (this will be my first and only reply here) nor do I intend to become one or intentionally use it again so don't bother yourself with your superhero supersmart remarks and replies because I know I won't be. It's 4 am and I felt like having a laugh via this petty little spiel. Finally in closing I'd just like to say FYA to all the losers and trolls marauding about such pages, you know who you are. Goodbye and happy reading. I'm going out for another joint now. I'm done!!!
    Reputation: 006_007's Avatar
    Quote Originally Posted by timo_665 View Post
    Welcome to MTBR - Really hope to hear from ya again!
    mbtr member
    oh the irony....
    Mikhail Kalashnikov
    So you brought up a 6yr old thread to tell us to grow up and get a life? I'm guessing there are no mirrors where you live. If I were you, I would put the joint down, you're already struggling in life.
    Oh, and to help you out a bit in your Google education based off of no actual work on your part, larger pads absolutely do not increase stopping power one bit. Not even a little. The main benefit is they wear slower. A smaller benefit is they have the potential to run a little cooler all else being equal. Piston force doesn't increase or decrease when you install larger pads. It remains exactly the same, it's just spread out over a larger area but with less psi giving no change in power. Just remember this little bit of info after you search to the ends of the internet and end up right back here at the same conclusion.
    Don't lie and say you won't be checking in. You took the time to register and reply to a 6yr old thread at a time you should be sleeping or getting laid. You have no life. You will be back to see what people are saying about you.
    '08 Hardrock HRXC
    '09 Epic Comp
    '14 Trance SX -
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    Bigger rotors make a difference.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Aug 2013
    So you are both, then.
    Anthem Advanced
    ECR
    Reputation: bigflamingtaco's Avatar
    Oct 2013
    Quote Originally Posted by Prophet Julio View Post
    Larger diameter rotors offer an increase in torque angle. "Bigger" does not implicitely imply "larger diameter".
    Bigger, however, could imply a greater mass, which would improve the heat-sink characteristics of the rotor, delaying the onset of "brake fade". Maybe you meant this as the difference you aluded to, and were completely factual, albeit vague, in your original statement.
    I hope this post has picked this subject apart to the satisfaction of all parties involved. Can't leave any stone unturned when there are drive-by posters lurking about the place.
    I will suffer no butt-hurt fools!
