Results 1 to 3 of 3
    Reputation: Lambone's Avatar
    Larger Front Rotor...help?
    Sorry if this thread is redundant...
    What do I need to put a larger front rotor on my Turner 5-Spot?
    I have XTR hydro calipers and a Fox Talas fork. I'm thinking a 175mm rotor would work better then my current 160.
    Thank you!
    Caliper Adapter
    Quote Originally Posted by Lambone
    Thank you!
    You can use our AD-486 Caliper Adapter to go to a 180mm/185mm rotor.
    www.discbrakeadapters.com
    Fat Is Where It's At Moderator
    Reputation: DiRt DeViL's Avatar
    Before attempting that verify with the fork manufacturer to see if they'll avoid the warranty by using a larger diameter rotor. Then you can get the adapter and install the larger rotor.
    In my case I had to jump from a 160 to a 203 in order to keep my current caliper. I changed from a IS fork (RS) to a post mount (Manitou) and had to install an adapter. For XC 203 is too much rotor but that's what works according to Shimano.
  1. Trade-offs in anti-squat suspension theory
    By derby in forum Bike and Frame discussion
    Last Post: 05-24-2010, 03:46 PM
  2. front derailleur adjustment question
    By KSC in forum Tooltime
    Last Post: 03-19-2004, 07:27 AM
  3. Replies: 2
    Last Post: 03-01-2004, 06:01 PM
  4. Why doesnt sram make any higher end front derailleurs any more?
    By TheRedMantra in forum Weight Weenies
    Last Post: 02-12-2004, 07:28 AM
  5. How to "tighten up" front geometry on NRS?
    By Srexy in forum General Discussion
    Last Post: 01-21-2004, 04:30 AM
