Results 1 to 7 of 7
    Kool stop pads + Juicy Ultimate?
    I tried to install some Kool Stop pads in my 2009 Juicy Ultimate calipers and they don't fit. The backing plates (aluminum KS-D270A) seem to be about 1mm too long to fit in the caliper opening. Anyone had this problem and is there a solution other than going to another pad manufacturer?
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Did you seat the pistons??
    Formotion Products
    http://www.formot
    Yes - pistons are seated. It's not the width, it's the length that is giving me trouble.
    Jan 2005
    Quote Originally Posted by MordiDP
    So if you lay the stock pad and the new pads back to back the new ones are longer.
    Formotion Products
    http://www.formot
    Quote Originally Posted by dogonfr
    I had that problem with some Alligator pads....I just filed the edges
    "To finish first, you must first finish"
    Yep - that's correct. Maybe I need to get the file out.
    Took the dremmel to the pad backings and made it work. Luv the kool stop pads.
