Results 1 to 2 of 2
    kooka racha levers
    does anybody know where i can get hold of replacement pivot bolts for my racha's.
    it's the bolt that holds the lever to the body. a ti or even steel will do as i recon the alu ones fitted aren't up to the task.
    Loose Nut Behind d' Wheel
    Reputation: Lucky's Avatar
    You could try www.thethirdhand.com...
    formerly known as Loose Screws/Third Hand Tools, assuming Kooka is no longer in business and you can't get screws from them. Third Hand may have something that will fit. You need to know the screw length and the diameter. It's almost certainly metric, and metric screws will be called something like M5 x YY or M6 x YY, where YY is the length in millimeters. M5 and M6 seem to be the most common sizes on bikes, though there are others. You'll also want to try to match the head style, be it a socket cap or countersunk head.
    BTW, never make the mistake I made a few years ago and type in loosescrews.com, assuming that's their website. What I found there had nothing to do with bicycles.....
    Kathy :^)
    Look where you want to go. This is as true in life as it is in mtbiking.
  1. What to do to prevent brake levers hitting the top tube!
    By fran in forum General Discussion
    Last Post: 06-15-2004, 06:09 AM
  2. Replies: 2
    Last Post: 03-08-2004, 07:59 AM
  3. Replies: 14
    Last Post: 02-06-2004, 03:49 PM
  4. Deore hydro levers w/ XT hydros?
    By seely in forum Brake Time
    Last Post: 02-04-2004, 07:05 PM
  5. New XT levers - reach adjustment?
    By jcw in forum Brake Time
    Last Post: 02-04-2004, 04:02 AM
