Results 1 to 45 of 45
    (aka SS_MB-7)
    Reputation: 1speed_Mike's Avatar
    King ISO front disc sets caliper too close...
    Although the LBS faced the Fox disc tabs to ensure they are parallel, when I installed the Marta SL caliper (without shims) and King ISO front wheel, the outboard pad is touching the rotor and needs to moved right (when looking head-on at the fork/caliper) several millimeters.
    I know this has been dealt with in the past concerning the various King/fork/brake combos that sets the caliper too close to the rotor (without any shims). Some have pointed the fingers at King, and at this point, I have to agree.
    This is my first King front hub (all my previous disc hubs were Hope Bulbs). I've never had an issue with any of the discs (Hope C2 Pros, Hope Minis, Hope Mono Minis, Formula B4s, Formula B4 SLs, Formula B4 SL+, Shimano XTR/XT and Magura Marta SL) that I've used on numerous forks, including a Fox/Marta SL. This leads me to believe that the King is the source of the problem.
    So, I can either:
    1 - use the Magura tool to continue facing the Fox tabs; or
    2 - use a 1mm washer between the Fox dropout (disc-side) and the King serrated washer which will push the leg outward.
    Since I don't have immediate access to the Magura tool, I tried #2 and it worked. However, I'm somewhat concerned that the flat washer against the smooth Fox dropout could potentially cause the wheel to dislodge in the dropout. I guess with enough skewer tension, and the serrated washer on the non-disc side would minimize this likelihood. Also, in thinking about it, my Hope Bulbs all have flat, non-serrated surfaces and I've never had any issues.
    So, what have you done to fix your problem?
    Ride Hard,
    Mike B. (MCM# 7.77)
    http://www.one-speed.com
    Do It Yourself
    Reputation: Homebrew's Avatar
    I really think it's a King issue as well. You really need to remove quite a bit of material (at least 1 mm) with the Fox/King/Marta combo and not just face them. I think it will improve as the hub breaks-in but not that much.
    It was really bad when I switched forks to a Manitou_Minute. The 180mm rotor was actually rubbing the post mount on the fork. I've since dropped down to 160mm which fits between the post mounts and works better. I've tried some other hubs and they have much more clearance than the King.
    Long Live Long Rides
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    Been there done that
    I posted about this a few months back. It's a bad combination for sure. Many have had a problem with that combo. I had to mill quite a bit off to get things to line up, and still needed microadjustments etc.
    I think most of the problem lies with Fox actually. I've heard of folks having problems with Hopes/king iso/fox forx also. I believe that all companies have things within ISO specs, but there is some leeway there. My guess. Fox has it's tabs as inboard as possible, and King likely has that shell sitting as "wide" as possible within spec. Put the two together with a caliper that doesn't allow outward adjustment, and you have a problem. I even sent a wheel to King to re-measure and they said it was within spec.
    Ultimately other frustrations led me to ditch my marta calipers, but I did have things centered and working for a bit. I did need to do the microadjust trick quite a bit.
    I don't like the idea of that flat washer though on the outside of the hub, I think you are right in that it may cause some slippage.
    Good luck with things. I got uncomfortable shaving the tabs at about 1.5mm.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    (aka SS_MB-7)
    Yep, I distinctly remember your post about the problems. And, I also recall why you ditched your Martas. So far, my Marta SLs are working amazingly well on my SS and I don't suspect any issues with them on my Racer-X. But, time will tell....as it always does.
    Ya, I'm not fussy on the washer either, but, I really don't think it's going to be an issue. Afterall, both Hope Bulb axle faces are completely smooth and after 5-yrs of racing and riding, I've never had an issue (knock on wood).
    With that said, I'm going to try and get access to the Magura tool to remove more material from the Fox fork.
    Ride Hard,
    Mike B. (MCM# 7.77)
    Jag
    Jag is offline
    Reputation: Jag's Avatar
    Hey Mike, can you
    Take a picture of your quick fix.... I to have the King, Marta, Fox combo with some of the same issues (the rubbing went away once the brakes were broken in...). My shop has the Magura Gnanomatic (sp?) and they took off about 1 mm.
    I bought an extra wheelset (XT discs), and found they rub horribly, so I shimmed the rotor on the XT front wheel to push the rotor out more. The front works ok now (switching from King to XT front wheels) however the exact opposite problem occurred with the back wheel (the XT rear axle seems longer than the King... Dooooppp ), Anyway for now I am just going to stick with 1 wheelset and maybe readdress it during the winter.
    Jag
    (aka SS_MB-7)
    Quote Originally Posted by Jag
    Sure, I'll do it tonight...but, there really isn't much to see. I simply added a thin washer on the disc-side of the King ISO front hub. The washer effectively moves the Fox leg outward, moving the caliper with it. This gave me enough clearance to run the caliper drag-free.
    Shimming the rotor would effectively make the problem worse since it is moving the rotor further into the caliper.
    Ride Hard,
    Mike B. (MCM# 7.77)
    Jag
    Jag is offline
    Yah but...
    Quote Originally Posted by 1speed_Mike
    In my case the brakes were set up initially with the King wheels in mind (longer axle)... therefore the XT front wheel (rotor) needed to moved out to match the King axle spacing...Basically I am saying that I agree with you in that the King front hub seem to be the culprit...
    The reason I would like a picture is for the sizing of the washer...
    Thanks,
    Jag
    Reputation: Jaji's Avatar
    wow, i have the exact same problem with King ISO disc front hub, Fox Vanilla forx, and Grimeca system 8 disc brakes. the outboard pad rubs against the rotor. so far all i have done to correct for this is file down the caliper mounting point but i dont want to go too far as it wont be perfectly prallel if i dont use some kind of vice/guide.
    (aka SS_MB-7)
    Here are some pics to illustrate the problem between the Marta SL caliper, Fox fork and King ISO hub. The caliper does not have any shims and is tight against the Fox fork's disc tabs (which have been faced already).
    By using a standard washer (OD = 19mm; ID = 9.7mm; and, t = 0.8mm), this helps offset the Fox's disc leg slightly, which provides the necessary clearance. Not ideal, but until I have access to the Magura Gnann-o-mat, this is all I can do.
    Ride Hard,
    Mike B. (MCM# 7.77)
    Same deal Fox / DT Hügi, not just King
    Had the same problem with my Fox TALAS, Magura Louise/FR, and DT Swiss FR hubs. I got the fork faced, and it was still too tight by about 0.7mm.
    After measuring the hub, caliper, and fork, it seemed to me the fork was furthest away from the target dimensions.
    I had difficulty finding any documents that specified what the tolerances were, I concluded IS2000 is kind of an informal thing.
    Another issue is the serrated washer, which digs into the fork legs by some unspecified amount.
    I ended up setting up the caliper in a mill and taking off 1.2mm off the mounting surfaces. Works great but don't do it unless you are ready to give up your warranty, and can make sure the surfaces come out flat and parallel to the original ones.
    I put a tad of Hylomar on the mating surface of the fork to help prevent corrosion to the mag casting when assemblng.
    Reputation: sdneal's Avatar
    Chalk me up as another on the list of CK Hub + Fox Fork + Marta brake that has rub on the outside pad. It's not super bad, seems to be < 0.5mm off. And if I take spin the front wheel it will spin for >30 seconds before stopping. I plan on taking my bike in to the shop this weekend to have them machine a little bit more off the fork mounts (after I go for a ride on Saturday).
    old enough to know better
    Reputation: headhunter's Avatar
    Have the same problem with '03 XT and CK
    I purchased a set of wheels based on the King ISO hubs and have the same problem of too far outboard rotors with the Shimano 755 brakes on a Fox 100 RLC. The front is particularly bad.
    My other XT-based wheels are fine. I'm wondering, use the 1mm washer or have the King hubs faced...
    Reputation: Treybiker's Avatar
    Oh, this is just great. I've been wetting my pants because my Fox F100X, Hayes Mag Plus, and CK wheelset will be here next week and I can't wait to throw everything on my Truth. Now I hear this. Well, I'm glad I heard about it now before I started building up my frame and not after I set it on fire from the frustration.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    yup...
    looks like king iso disc hubs space the rotor too close to the fork. atleast if it's spaced closer towards the center of the hub, you can use spacers to ove the caliper that way.
    i tried calling a few shops that carry high end stuff, and i had to repeat "do you guys do disc tab facing" with each shop rep. about 3-4 times, they didn't have the slightest clue to what that is. finally found one shop that has it, $30 and a week wait for my bike to be done....fogettaboutit.
    i've got a king iso laced to a alex td17 29er rim. i tried to use a 03 xtr caliper with my rigid kelly disc fork, no dice. then, switched the caliper to a mono mini, and the clearance is ok, after i scraped some of the excess paint off the inside of the tab (don't try this unless you've got some major balls). everything seems well now, but tomorrow will be the true test, i'm taking my bike out for a long ride tomorrow. should be ok though. seems like alot of people have this problem, especially with the fox fork/king iso/marta set up.
    i'm starting to like that cheap ass real disc hub i got free from a buddy (and they are $15 on ebay). it's built like a king, however the company is dead. i've got about 400 miles on it and not a single problem and the bearings are even smoother than the day i bought that thing home.
    cheers!
    So, I can either:
    LBS Helped Me Out
    My LBS, Louisville Cyclery here in scenic Louisville Colorado, took a look at my problem. It took about two minutes of diagnosis, the guy handed me a couple of shims for the rear brake, gave me a little insight into my brake system and I went home of dialed it in.
    FWIW, the front brake is maxed out on adjustment, but I was able to get it to work by taking out all shims and washers on the front brake.
    Nothing like an experienced mechanic. Also, they didn't charge me a cent. Guess where I'm getting my next road gruppo...
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Same, same
    Same old story with me. King ISO, Fox F80 RLT, and Hope Mini brakes. It was also ugly on the Kelly rigid fork. I had the Fox faced, and it still sucked. I got Juicy, and with the amount of side adjustment allowed, it's all good.
    rickyd
    Kam
    Kam is offline
    A hopped on pop.
    hmm...
    yea, i thought the avid mech discs were my last hope, before i took a chance with the mono mini. i ran the mono mini brake yesterday for a 25 miler, no probs with rubbing!!! thank god, i really love the feel and modulation of a good set of hydros.
    then, i remembered that the avid juicy also use the cps system, and it got me thinking, maybe use a juicy up from??? i may get a wb bw.8 fork for my 29er, and the juicy will probably be the best way to go when i want to swap forks.
    hey drevil, love your utilitiman!!!
    cheers!
    Quote Originally Posted by Drevil
    rickyd
    Quote Originally Posted by Treybiker
    The Hayes brakes have the post mounts, which allow easier alignment without using shims. I'm getting King hubs which I'll be using Hayes hydro. brakes with. Is there enough adjustment with the Hayes brakes to avoid the rub being discussed?
    Well, according to my buddy, the rest of my parts (Hayes, F100X, CK wheels, etc.....) should be in from QBP tomorrow. I'm going to ride my single speed with him and his shop guys tomorrow after they close and then (start to) build it up and drink some beer when we get back. I'll let you know what I run into if I get that far.
    just in case you didn't read the go-round from a few months ago, I contacted King in March and this was their reply ( they have a point in that the machining process is more accurate than the casting of the fork legs):
    Sent: Monday, March 08, 2004 10:55 AM
    Subject: Re: clearance issues with Iso front hubs and Fox forks
    Hi Bill,
    I have heard of this issue with about every imaginable combination of fork and brake. All I can offer to do for you is to have you send in your hub and we will measure it in our machine shop to make sure it it within the ISO tolerance specifications of .401" +- .010". Since we have been manufacturing the ISO hub I have never had one come back that was out of spec. You are still welcome to send it back though. Please let me know if you would like to send it back and I will assign you an RA#.
    A good thing to keep in mind is that machining is a more accurate manufacturing process than casting of forging.
    Thanks for your patience. We have recently relocated to Portland and are still getting settled in.
    JEN
    Tech/Warranty
    King Cycle Group
    2801 NW Nela Street
    Portland, OR 97210
    503.972.4050
    Iso?
    Quote Originally Posted by OLAK
    Hi Bill,
    JEN
    Tech/Warranty
    King Cycle Group
    2801 NW Nela Street
    Portland, OR 97210
    503.972.4050
    What does a Chris King "ISO" hub have to do with ISO (as in www.iso.org)? Are they using "ISO" as a brand name or what?
    Do It Yourself
    Quote Originally Posted by dave_f
    There is an International Standard spec for disc brakes which includes measurements and tolerances on calipers, rotors, hubs, fork mounts, etc so they can all work together. Several years ago everyone had their own mounting, 4 bolt Formula/Coda, 5 bolt Hopes, 6 bolt Hayes etc. Now almost everyone follows the 51mm mounts and 6 bolt rotors. The most noteable exceptions would be Manitou's insistance on 74mm Post Mount and Shimano's centerlock rotors.
    Anyway, King used to sell a universal disc hub that used adapters for the many different mounts. Since almost everyone adopted the IS 6 bolt rotor mount, King decided to make an IS specific hub and called it the ISO Disc.
    follow you so far
    Quote Originally Posted by Homebrew
    ...King decided to make an IS specific hub and called it the ISO Disc.
    I know it sounds like splitting hairs, but calling an "IS specific hub" the "ISO Disc" may be misleading. Maybe the following could help:
    Statement:
    "we will measure it in our machine shop to make sure it it within the ISO tolerance specifications of .401" +- .010"
    Possible translation 1:
    "we will check it to make sure it's within the manufacturing tolerances of the design specifications we made up for that part. Whether anyone ever has or will make a fork or brake that will work correctly with it is unknown."
    Possible translation 2:
    "we will check it to make sure it's within the manufacturing tolerances as specified in IS(O?) standard number xxxx, revision y.y which ensures that forks and brakes manufactured in compliance with that standard will work together."
    Which translation should I be reading?
    ISO publishes standards: thats exactly what they do. Information on what they are and how they are funded is available on their website. maybe you should be the chairman of the bicycle comittee Big advantage to manufacturers is that their stuff will bolt on to other peoples stuff. With Shimano, they feel that they are big enough that people can just damn well buy their BB for their cranks
    Do It Yourself
    I'm sure there is an ISO number but have no idea on specifics. There are CAD drawing on the Hayes website. Maybe you can glean what you are looking for there. Or maybe contact Chris King for more info.
    http://www.hayesdiscbrake.com/tech.cfm
    info@chrisking.com
    Statement:
    ISO is pretty specific and much more meaningful. it is not necessarily the same as IS. I can assume that there is an ISO published standard for bicycle disk brake hubs, which includes the dimension mentioned above. Maybe you can do some research on this and get back to us.
    Actually, I did have a look at the ISO page referenced, and at the drawings and info posted by Magura, Hayes, etc. when I was trying to figure out which part was out of spec. I originally intended to bring up the issue with whoever was advertizing their stuff as being ISO (or IS2000 or whatever) compliant when it doesn't comply (or so I thought, cause it doesn't fit together).
    I can find no reference to an ISO standard covering disc brake dimensions for bicycles. If anyone has the reference number, feel free to enlighten me.
    Till then, I doubt that they will make me chairman, since I don't believe in the existence of their disc brake spec .
    I will try mailing Chris King and see if they reply. Don't know why they should, it's not like it's an essential problem, or that they are going to sell me something. Customers first.
    In the meantime, I stand by my belief that the statement "IS(O) standard" adds about as much value to a fork/brake/hub as "Meets all applicable standards for use on the planet Mars."
    rack admirer
    Reputation: Mr Magoo's Avatar
    Marzocchi/King/magura same rub
    I have a 2000 Z-1 CR with 00 Magura Louise. Ran in XT hubs for 3 years with 2 .5mm shims in the front. Switched to Kings, no shims and get some inside rub. Has anyone considered facing the 6 hub contact points to create space instead of shaving their fork tabs?
    MCM # 57
    Quote Originally Posted by Mr Magoo
    Yebbut two points (on the fork) are easier than six points. What would you use? How would you ensure evenness/flatness on all six points? Seems like there is a greater chance of error when doing it on the hub.
    simply me
    Reputation: bostonkiwi's Avatar
    In this case facing the hub surface would move the rotor in the wrong direction. You would actually want to shim the rotor to move it away from the inside pad..
    rack admirer
    Very Sharp!
    I'm sitting here at work, making a drawing and you are correct.
    Now, any thoughts on shimming the 6 rotor bolts to equal (zero minus one) caliper shim?
    Might I get some howling from harmonic vibration?
    MCM # 57
    simply me
    you can use 6 caliper shims on the rotor (one for each bolt). however shimming the caliper has the same effect. either option will fix rubbing on the inside pad. it's rubbing on the outside pad that needs metal removal.
    rack admirer
    back to facing, not shimming
    I need to face (reduce) either the hub, the caliper, or the fork to create some breathing room between the left side (single piston side). I need to state at the bike before I post any more. Thanks for the help. All suggestions appreciated.
    MCM # 57
    Do It Yourself
    I would definitely go with facing the fork with a Magura Gnan-o-mat or similar Hope tool.
    rack admirer
    more info: rentable from Hammerhead
    http://shop.hammerheadbikes.com/site...=47&sort=Price
    I'd like this to be as convenient as possible, while I don't ride every day in summer, a long ride to LBS, leave off, and long drive to pick up during shop hours can eat up alot of days. thanks for the help.
    MCM # 57
    (aka SS_MB-7)
    Re-uploaded the pics....
    Ride Hard,
    Mike B. (MCM# 7.77)
    Reputation: Dougal's Avatar
    I'd be worried about that washer and your fork. It all depends how tight the lower bushings run, but it could make them bind a little. Do you notice any more stiction?
    The king measurement comes out at 10.18 +/- 0.25mm which compares well with the hayes drawing of 10.15 +/- 0.1mm, with the exception of their tolerances being over twice as big I though CK would have the tightest tolerances.
    I've got a few hubs here I was going to measure (formula, shimano, Real), but I left my verniers at work.
    I should add that any machine shop can face any frame, fork or caliper to work. Possibly cheaper and easier than finding a bike shop with the tools and knowledge.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    Some additional info
    Quote Originally Posted by Dougal
    As suggested elsewhere in this thread, I did eMail Chris King asking about the whole ISO thing. Someone did get back to me promptly (Chris king gets bonus points from me for having a good ethic here) and to paraphrase, they said "go ask Hayes". So, I',m not surprised their dimensions match the Hayes drawing.
    Magura and DT spec 10.4mm in their drawings, and my DT Swiss hub measures 10.4 +/- 0.1mm.
    The only other fork/brake/hub company I found (other than CK) who mentions "ISO" anywhere is Pace. I was able to ask someone knowledgeable from Pace at the Eurobike trade show about it, and they confirmed that there is no ISO (as in International Organisation for Standards) brake standard. Their response was that there is a sort of industry standard floating around, and that Shimano is the authority people go to with questions about dimensions.
    I should add that any machine shop can face any frame, fork or caliper to work. Possibly cheaper and easier than finding a bike shop with the tools ...
    I agree.
    ...and knowledge.
    That's the part I'd be concerned about.
    Reputation: D.F.L.'s Avatar
    Aftermarket to the rescue!
    it's time for someone to step up and produce some correctly re-spaced Kinng replacement parts. There seems to be a market and Kingg is generally too overwhelmed by demand to be able to offer such a thing. These would be easy to produce.
    I run an '05 Vanilla with Kiing and Aphid mechanicals (180mm rotor on Haze adapter ) and the rotor comes extremely close to the adapter, and it has rubbed occasionally due to flex.
    PS: IS disc mounting is a crappy system. Posts mounts make much more sense. It's dopey to stick with it just beause it's what we already have. But that's the bike industry...
    trouble here too.
    I have a King/Manitou Black/Hayes HFX Mag combo here. In my case, I had to move the rotor closer to the caliper because the slots on the caliper would not move enough to eliminate rubbing. I ended up putting washers between the rotor and the hub... no problems to speak of so far. Also, I had Avid mechs before... they worked fine, I'm assuming because the CPS bolts allowed more movement. But when I smashed my front wheel and swapped in an old one built on a Real disc hub, I had to readjust the caliper all over again. So my King is definitely different than at least the Real hub.
    Quote Originally Posted by slowride
    That wouldn't be an 02 black would it?
    I remember some of those were sent out with the caliper holes too far outboard. The 02 black on my girlfriends bike (fork bought second hand) appears to be one of these, when I put a mechanical caliper on it yesterday, I could only just get it to stop scraping the caliper on the inside.
    This was using a Real hub, I tried my specialized (formula) hub at one stage with the same results.
    SPV Devolve
    I measured my Kiing and my Foxx...
    International Standard calls for the caliper mounts to be 4mm + - .1mm outboard of the dropout face.
    My Ffox measures 3.91mm. .09mm too inboard, but still within spec. The fork is contributing somewhat to the problem.
    Shermano and Haze hub specs dictate that the rotor mounting surface should be 10.5mm + -.1mm inboard of the dropout clamping surface.
    My Kinng ISO front hub '04 model measures 10.06mm. This is .44 mm off of the standard, and .34mm out of spec.
    This hub measurement was taken from the top surface of the steel knurled surface of the Kingg. This surface will bite into the fork dropouts, bringing the rotor position even further out of spec. I'm not able to accurately measure this, but it looks to be .1-.15mm deep. Take that for what it's worth.
    I don't have any of the mentioned brakes, so I can't measure them, but it seems like the Kiing hub may be creating most of the issues.
    I'm hanging onto mine, though
    I don't really know for sure, but probably... it's a gray Elite with the letters that fell off. Also got it second hand, and at the price I paid, I'm happy to use washers to make up for it. My initial thought was, however, that the holes were off...
    Whenever you are setting up an international standard mount hydraulic brake such as Magura, Hope, Shimano, etc., you need to ensure that the caliper is centered over the rotor, and each is in parallel with each other for the best performance. Sometimes, you can get away with not having to do this work, but you will not get the full performance out of the brakes in my opinion. Granted, machining the tabs will place the caliper in a parallel plane with the rotor and will help performance, but sometimes the caliper will still not be centered over the rotor ensuring equal piston/pad movement. So, you have to do more facing of the tabs or use shims to ensure the caliper is moved in the necessary direction to center it over the rotor. In the case of the Marta/Fox/King combo, I have to nearly remove 1 to 2mm of material in most all cases to get the caliper over the rotor. I work on a lot of Magura product as well as a lot of other disc brakes and that combination is always a lot of work to ensure proper set-up. For people wanting to use mutiple wheelsets on one bike, Syntace has a new product that I just got in the store. They are disc brake rotor shims that allow you to shim the rotor by placing the shims in between the rotor and hub. If you go to Syntace.com and look for the disc shims, you can see a picture of them. It will take some time during set-up of all the wheels and brake system, but now you will be able to run multiple wheelsets on the same bike and not have to worry about re-shimming the caliper everytime you change your wheels.
    Frank
    Old man on a bike
    Interesting thread,
    in that I have an 02 Marzocchi Z1FR QR20+ with a King ISO Disc (20mm) hub with Avid mechs and I used shims on both the fork and the rotor mounts for the best solution.
    Now you need to expect to shim the caliper over 5mm since you're using a 110mm axle instead of 100. That wasn't quite enough so I shimmed the rotor with some washers I had and it lined up perfectly. I never really thought it was any one component's fault, just that I had three different manufacturers and tolerances involved and once I knew that lots of disc brake setups required shimming to align the caliper properly, I didn't worry about it. Sounds like the problem is all over the place from the above.
    I'm positive the King hubs were called ISO only in relation to the change in rotor mount from their Universal Disc model (with all the fun adapters for systems that mostly don't exist now) that preceded it. Otherwise I'm sure King is well aware of industry standards and does their best to be in compliance with them? I have plenty of King headsets and hubs and I've had no other problems with tolerances (other than my fat butt breaking a rear axle on the ISO rear hub, now I have their "heavy duty" version derived from bmx hubs). Maybe it's the quality of work done by King in Redding (hope rain is better than heat now that they're in Portland?). I have no way of measuring any of this stuff myself, but I'll keep my eyes open now.
    suum quique
  1. XT disc v. Hope XC v. King
    By Earthpig in forum Wheels and Tires
    Last Post: 07-13-2004, 11:38 PM
  2. Looking for front disc XTR caliper
    By crash_man in forum Weight Weenies
    Last Post: 07-12-2004, 12:11 AM
  3. Replies: 14
    Last Post: 04-23-2004, 02:35 PM
  4. Creak with king disc hubs
    By Enel in forum Wheels and Tires
    Last Post: 03-25-2004, 07:42 PM
  5. Replies: 2
    Last Post: 03-09-2004, 04:06 PM
