    kcnc v-brake lacking bite
    took my rebuilt adroit out on its maiden voyage and noticed my kcnc rear brake had little to no stopping power. Has anybody else had this problem? , do I need different pads maybe? , any suggestions.
    Did the pads on the rear get broken in?
    If not, I would guess rim contamination. Do you use spray lubricant on your drivetrain, and maybe accidentally got it on the rim? You can clean the rim with rubbing alcohol to get anything greasy off.
    You also might need to check your pads for contamination. You can search for how to decontaminate pads, but that usually is only applicable for disc brake pads. You can either sand off contaminated layers of the pads, or get new ones.
    Good luck.
    Bamboo is real.
    Everything is new so contamination should'nt be the problem, was wondering if maybe I got a bad set of pads. Will sand the surface before my ride to work this a.m.
    Bicyclochondriac.
    Quote Originally Posted by norsk biker View Post
    Pads might just need to bed in and mate to the rim surface. You might check how they are contacting the rim.
    What kind of pads? Some are much better than others.
