Results 1 to 5 of 5
    Flying Goat
    Reputation: mrpercussive's Avatar
    Juicy5 Master Code Caliper
    I think i've seen it done before... What do i need? New fittings? New caliper mounts?
    Meh.
    Reputation: XSL_WiLL's Avatar
    You'd need the Code caliper (obviously) and the bleed kit. The Code banjo bolt is specific to that caliper. So you'll need a new Code specific line.
    All Juicy brakes newer than 2004 use a M8x.75 fitting at the lever, so does the Code. So you should be good there. I don't think there were Juicy 5s 2004 or 2003, so that's not an issue. But for reference, 2003/4 Juicy brakes use a M8x1.0 inline fitting for the lever.
    The adapters and all that are the same.
    Flying Goat
    so i'll need new fitting for the caliper, new brake line, the caliper and bleed kit... is that right???
    Meh.
    The fitting is already attached to the line, so you need the Code hose. You need the caliper. The Juicy bleed kit works for the Code (if you don't already have it).
    Flying Goat
    sweet... thanx...
