Results 1 to 3 of 3
    The Riddler
    Reputation: Kaparzo's Avatar
    Juicy Ultimate Setup Tips
    I know its really easy to setup Juicys but for some reason I'm having a little difficulty getting the calipers to align without rubbing. Anybody have any ideas or tips to offer? Any help would be great.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Check to make sure that you haven't maxed out the side to side adjustments either way. If you have, you'll have to space over the adapter to move it inboard, or face the tabs to pull it outboard (shimming the rotor will effectively accomplish the same thing).
    Also make sure that you start with the pistons all the way in their bores and that you don't have a sticky piston.
    did you make sure the pistons aren't overextended just a bit? I always seem to have to jam a screwdriver in there and push the pistons in that extra little bit to prevent drag.
