Results 1 to 13 of 13
    featherweight clydesdale
    Reputation: Fattirewilly's Avatar
    Dec 2001
    Juicy Ultimate - forward lever click
    I bought a used bike with Juicy Ultimates. If you push the brake lever forward beyond its natural, all the way released position, it clicks forward about a 1/2 inch into another position. What is that feature for?
    Never trust a fart
    Reputation: frdfandc's Avatar
    Its to help prevent you from snapping off the brake lever if you go over the bars when your hands hit the levers.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    No, it's to prevent you from accidentally grabbing the brake when you take the front wheel off.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by Berkley
    Yup . . . I asked my LBS this exact issue when I got my Elixir's . . . thats what they told me, and it makes sense. It's a warning/back-up in that it will engage to its normal catchpoint before it moves the piston.
    Never trust a fart
    My bad. Some one gave me bad information. I hate passing on bad info.
    Reputation: s0ckeyeus's Avatar
    Quote Originally Posted by frdfandc
    I've heard both as well. I'm not sure about crash protection, but my Juicy 5's often click out whenever I hit the dirt.
    Big Gulps, Alright!
    Quote Originally Posted by s0ckeyeus
    Probably a side effect of the original intended purpose. That little amount of movement isn't going to provide a whole lot of lever protection. In fact, I crashed a couple days ago and broke my Juicy's lever body at the bar clamp. The CF lever blade was intact. Those suckers are stronger than you'd think.
    Yeah, probably.
    Dec 2001
    Thanks, this makes sense.
    Meh.
    Reputation: XSL_WiLL's Avatar
    No. It is intended to isolate and prevent damage in the event of a crash. The pushrod is not directly connected to the MC.
    It just so happens to help you prevent actuating the brake... but anything more than a slight bump can push it past the detent.
    +1
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I thought the purpose was to generate forum threads?
    Quote Originally Posted by JonathanGennick
    That was a side product of the intended purpose.
