Results 1 to 3 of 3
    Juicy Ultimate caliper same for different rotors?
    The Juicy Ultimates are offered in 140mm rear, 160mm front and rear and 185 mm front kits.
    Question no 1: Is if the caliper in the front and rear is of the same type? If same, shouldn' t I be able to buy a 160mm rear kit and just change the rotor and adapter to get 185mm rear?
    Question no 2: Is there a difference in hardware between buying the 185mm front kit and buying a 160mm front and changing rotor and adapter to 185mm?
    Combatjojje
    Meh.
    Reputation: XSL_WiLL's Avatar
    The calipers are all post mount calipers attached to adapters. The calipers are the same for front and rear and all different sizes, it is the adapter that is different.
    Thanks for clearing that up for me!
