Results 1 to 3 of 3
Thread: Juicy Failure
    Poser
    Reputation: direktor's Avatar
    Juicy Failure
    So after my run-around with getting a proper seal at the hose/lever the other week, now this:
    Last night I go on a new ride, a pretty gnarly fireroad climb and decent. Never made it to the singletrack before dark, so we came down the fireroad. Steep fireroad. The entire way down, I was stoked on how well the Juicys were hanging in there.
    So tonight, I grab the rear lever and notice some sponginess. Not a surprise, as I figured the brake workout last night brought some air out of the lines and it was now collected somewhere.
    I bleed (my best job yet), finish up, give the lever a good squeeze, and the caliper audibly squirts fluid all over everything. One look and you can tell it came from a piston.
    So did the heat toast the piston seal? Or is it possible I did something weird during the bleed and unseated the seal?
    With some brakes, you can dislodge the piston by squeezing the lever while the caliper has nothing to bite (i.e. a rotor). Any chance that happened?
    I for one, am not impressed with my Juicys.
    Poser
    Nope. The caliper was always on the rotor while bleeding.
    Just for the benefit of the class, I'll follow up. I called SRAM of course, and the honestly helpful guy I spoke with told me to just take it in to a shop, have them call it in, and he'd send a new one to the shop.
    I don't want to get the guy busted, but he mentioned there were some early calipers that had sealing problems between the two halves, and thought that might be my case.
    I had to buy a mechanical though to keep riding...bummed about that.
  1. Avid Juicy 7 n00b questions.
    By martynda in forum Brake Time
    Last Post: 09-22-2004, 07:52 AM
  2. Juicy rant | Mtn high cyclery rave...
    By incubus in forum Brake Time
    Last Post: 08-03-2004, 07:19 AM
  3. Enduro Owners Hayes HFX 9 or Juicy 7's?
    By CCRiderKY in forum Specialized
    Last Post: 07-20-2004, 01:27 AM
  4. Avid Mech / Juicy adapter & rotor compatibility?
    By El Kabong in forum Brake Time
    Last Post: 05-28-2004, 09:01 AM
