Results 1 to 6 of 6
    Juicy Carbon Break IN ?
    Just got a new set of Juicy Carbons, and they feel kind of mushy, Ive read just about every thread regarding the adjustments and the different things that could be wrong .
    Do these brakes have a break in period ?
    ...idios...
    Reputation: SteveUK's Avatar
    Mushy most likely means that they need bleeding. Try adjusting the lever throw first to make sure that it's correct for your hands.
    Diogenes
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    proper bedding period and a bleed would be a good idea...the avid factory bleed is poor
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Nov 2007
    Sounds like a bleed. Avid says they are "pre-bleed" but often times they need one. My front needed a bleed but my back brake is fine, so its really hit and miss
    I had the shop install them, so you mean to tell me that they already come pre-assembled and all they do as slap them on the bike ?
    Riding free's the mind
    Yeah it takes a few rides with some long fast downhills to break in the rotor/pads. At first brakes feel weak, with not much grab. So having to pull the levers harder because the pads/rotor are not broken in also contributes to the mushy feel.
    Question to a custom frame builder..."So what makes your bikes climb better?"....his answer, "Uh, your legs?"
