Results 1 to 11 of 11
    TM1
    TM1 is offline
    Juicy brakes on CenterLock Hubs ?
    What is the best way to put the Juice on the hub ?
    Is there an original Avid rotor for centerlock ?
    Is there an adaptor to do the job ? Is it working OK ?
    THX
    There are quite a few Centrelock to IS 6 bolt adapters available now, but the best looking/functional/made one would definately have to be the dt swiss one. visit their site for more details.
    There are also ones available from problem solvers, and also a few on ebay, but not sure of their brand ?
    From what ive heard people like the adapters on centrelock hubs for the weight savings and ease of installing/removing rotors (ie not having to undo 6 bolts)
    Also Galfer are currently making their centre lock rotors at the moment, but last i heard they werent available just yet ? this may have changed now, maybe email them ?
    TM1
    TM1 is offline
    Thx, I ordered 2 "Problem Solvers" Centrelock to IS 6 bolt adapters. I hope it will work.
    Anyone have some experience with these adapters ? I'll use them with Juicy-5's.
    Reputation: shiggy's Avatar
    Dec 1998
    The DT Swiss Centerlock to 6-bolt adaptor is very sweet.
    mtbtires.com
    Chrome Toaster
    Reputation: Hecubus's Avatar
    The DT swiss is definately the most elegant solution. You can also buy a set of shimano centerlock rotors in the size you need.
    TM1
    TM1 is offline
    Shimano rotors with Avid Calipers ...
    will void the warranty. So I was told by the local dealer.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Bull!!!!!
    Quote Originally Posted by TM1
    That's a bunch of bull. Rotors are rotors. Thats like when the print manufacturers were trying to void warranties for using recycled cartridges. They got shot down.
    Quote Originally Posted by shiggy
    I'm using these and agree that they are pretty slick, not funky at all. Here are some pictues:
    DT Swiss Centerlock Adapters
    TM1
    TM1 is offline
    BTW, which rotor size to get ?
    For an XC-trail rider. fast single-tracks. minimum air-time.
    200 pound, 6'2" high.
    my rig - Azonic Propulsion 4" w/ 2005 float-r and Marz.MX air.
    I am about your weight, ride Stumpjumper FSR120 that came with 185mm front 160mm rear, same kind of riding, work great for me.
    BTW, I swapped the rotors onto DT Swiss 240s Centerlock hubs using the aforementioned adapters with no problems at all.
    Chrome Toaster
    It won't. Its the same thing as using any aftermarket rotor. Rotors are rotors. Im just saying you can consider this because it can sometimes be cheaper to buy the rotor than the adapters and its a cleaner setup to not have to mess with adapters sometimes.
  1. What are the BEST brakes on EARTH?!
    By norwoosg in forum Brake Time
    Last Post: 02-24-2005, 10:38 PM
  2. Replies: 37
    Last Post: 01-30-2005, 09:03 PM
  3. Saint brakes with non shimano hubs?
    By ixi in forum Downhill - Freeride
    Last Post: 12-02-2004, 07:04 PM
  4. xt centerlock hubs, hayes mag brakes: what rotors?
    By Turtle-Dog in forum Brake Time
    Last Post: 12-01-2004, 03:04 PM
  5. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
