Results 1 to 5 of 5
    Reputation: ad..'s Avatar
    Oct 2010
    Juicy 7's tweaking front wheel
    This may be silly question... Maybe it's just the nature of disk brakes (I've always run v-brakes prior to my current set up)...
    Under hard breaking I can visibly see the front wheel tweak to the left, the rotor side of the wheel. Is this normal for disk brakes?
    I'm running juicy 7's, 160mm rotors, SRAM 9.0 hubs, Salsa Delgado rims, RockShox sid team fork.
    ups and downs
    Which vintage of SID? The older series with the small stanchions or the new 32mm stanchions?
    Oct 2010
    2008 SID, with 32mm stanchions. Setup at 80mm of travel.
    Reputation: knl2stl's Avatar
    Jan 2011
    Does the front wheel tweak to the left and then go back to where it was, or does it tweak to the left and stay there? Disc brakes can cause the wheel to slip a bit in some fork dropouts. If this is your case, and you have a quick release up front, try a harder clamping QR like a Shimano XT.
    Oct 2010
    The wheel returns to normal position as soon as I let off the brake. The QR is nice and tight, Salsa QR. It's not a major problem, I just notice it under hard braking. Always wondered if that just the norm for disk brakes.
  1. Juicy 7 caliper rubbing on front wheel spokes
    By robe in forum 29er Bikes
    Last Post: 08-22-2009, 03:05 PM
  2. Juicy 7 Front Wheel Rub
    By Fuel_81 in forum Brake Time
    Last Post: 08-16-2009, 01:18 AM
  3. Installing Front Wheel with Juicy 5's
    By brunowakeup in forum SRAM
    Last Post: 09-12-2008, 01:52 PM
  4. Replies: 3
    Last Post: 07-29-2008, 03:59 PM
  5. Any way to modify a rear disk wheel to fit as a front wheel ?
    By th3crack3r in forum General Discussion
    Last Post: 04-05-2007, 05:43 PM
