    Juicy 7 reservoir kits
    After realizing that I have a bad reservoir seal in my J7's (stock on my 2005 Prophet 1000) I ordered a replacement reservoir kit from Chain Reaction Cycles (well 2 actually) but have to wait till end March till its in stock? Anyone know why such a long wait time? Could this be due ot huge demand because of this know issue of perishing reservior seals?
    This may force me to swap over to a different brake set as the bike is unrideable in its present condition (not so bad as it lets the SuperV get some air).
    Thanks, TonyG
    Meh.
    Reputation: XSL_WiLL's Avatar
    Go to your LBS and have them order it.
    Both BTI and QBP have the parts in stock. Your shop should be using atleast one of them as a distributor.
    Dec 2005
    Quote Originally Posted by tonyg
    Thanks, TonyG
    are you talking about the master cylinder cover bladder? just get some of this to seal it and hold you over:
    Permatex® Form-A-Gasket® No. 2 Sealant
    Slow-drying, non-hardening sealant designed for sealing cut gaskets and stamped parts. Allows for easy disassembly if required. Temperature range -65°F to 400°F (-54°C to 204°C); resists common shop fluids and fuels. Use where sealing is more important than adhesion.
    cheers for the replies. Think I will try to source the kits elsewhere - sounds like I should be able to find these easy enough.
