Results 1 to 9 of 9
    Juicy 7 Caliper Adjustment Problem
    I was playing around with my new 7's before mounting the caliper and after I removed the red caliper spacer, I was not able to get them adjusted wide enough to get the rotor to fit, even after going to both extremes with the adjustment knob.
    Anybody have any suggestions, less bleeding the system, as I do not have a LBS within 70 Miles, and my bleed kit is currently in the mail. Thanks all!
    you can pry them apart with a flat metal object. I have used 2 putty knives with sucess
    thanks, will try when i get home
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    yep, pry them apart...and just an fyi...the red contact knob does not move the pads
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
    Calm Like a Bomb
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    Thanks for the prying advice it worked like a charm...now I just have to figure out why the alignment is all out of whack
    Calm Like a Bomb
    just loosen the cps bolts, squeeze the lever a few times, keep the lever squeezed then at the same time retighten your cps bolts in an alternating fashion...if there's still some rub after that, find the side that's rubbing and place a business card between the rotor and the pad on that side and go through the above directions again with the business card in place
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    Quote Originally Posted by pipes10
    What are the "cps" bolts?
    Anybody can ski the groomed
    sweet!
    Reputation: Diamondhead's Avatar
    Nov 2007
    Quote Originally Posted by cmon4day
    CPS stands for caliper positioning system.
    Refers to the caliper mounting bolts and the cone and cup washers.
    Good Luck!
    "It's a Sledgehamer" "Dang! You got shocks, pegs...lucky! " Napoleon Dynamite & Pedro Sanchez
