    Carb free mofo
    Juicy 7 bolt - help with size
    I'm not going to name names but someone overtightened the bolt on the lever clamp and I've had to drill it out. It's currently held on with tape 8)
    What size bolt is this? Not sure of the year, but it is a single bolt clamping the lever to the bars.
    In the future, there is only war.
    Reputation: cant fix a flat's Avatar
    on the lever clamp, there are 2 bolts not 1. i have an extra set, send me a pm with your address and ill send you the bolts.
    Reputation: Jason B's Avatar
    You want the lever to be able to rotate on the handlebars if they take an impact (so that the lever does not break in some way). This is why a torque wrench is suggested when putting things on bikes.
    Carb free mofo
    Like this:
    Like the one on the right hand side.
    I'm running an old Juicy 7 on the left (1 bolt) and a juicy 7 carbon on the right (which is 2 bolts).
    I need the bolt size for the single bolt brake.
