Results 1 to 6 of 6
Thread: Juicy 5 vs 7?
    Juicy 5 vs 7?
    My bike came with Juicy 5's, is there any reason to upgrade to the 7's?
    What would be the pros of doing this?
    '08 Top Fuel 8
    Bontrager RXL CF bars & seatpost :: RXXXL CF stem
    M970 XTR pedals :: X-0 gripshift :: X-0 rear derailleur
    Meh.
    Reputation: XSL_WiLL's Avatar
    Same brake. The J7 just has the knob on the lever to adjust the throw (distance the lever travels before engaging).
    Thanks. That's actually a feature I'd like. I may just upgrade. Thanks!
    '08 Top Fuel 8
    can just the levers be bought and installed or do you need to buy the whole system. im in the same boat as Lt. Dan
    Meh.
    Just the MC body should be able to be purchased by an LBS through one of their distributors.
    sweet!
    Reputation: Diamondhead's Avatar
    Nov 2007
    They both use the same caliper, only the lever assy. is different, however they both use the same levers...did that make sense?
    EDIT: I see XSL_WiLL beat me to the punch with a much better answer
    "It's a Sledgehamer" "Dang! You got shocks, pegs...lucky! " Napoleon Dynamite & Pedro Sanchez
