Results 1 to 3 of 3
    Reputation: farmertan's Avatar
    Juicy 5 lever return
    My Avid Juicy 5ís that came on my Stumpjumper are about 9 months old. The lever does not return quickly after braking. The brakes donít feel spongy when braking, but right afterwards the lever has a lot of play. It takes about 10-15 seconds for the play in the lever to dissipate. I donít know if the issue is the calipers or the levers. I have Juicy 7ís on my other bike and my wifeís bike has Juicy 5ís; neither has this issue. Iíve tried spraying lube in the lever pivots, but no success. Anyone have this issue or have any advice? Thanks.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Pull everything (lever, knuckle, pushrod) out and clean thoroughly. Sometimes stuff just gets gunked up in there. I had an issue with Loctite getting on everything.
    If that's not the issue... try bleeding it. Otherwise, sounds like it's a MC issue.
    Jan 2005
    The seal inside the lever (next to the spring) may be damaged, I had that same issue with my Juicy 7 front brake and although I didn't have a replacement seal was able to fix it. The seal was slightly damaged on one end and a small piece of rubber had come off and may have blocked the movement.
