Results 1 to 5 of 5
    Feb 2007
    Juicy 5 brakes still mushy after bleeding...
    I've put on new pads, bled the brakes 3 times, verified the calipers are working, but my brakes are still mushy and not very good. Any ideas?
    Thanks.
    Sheffield,South Yorkshire
    Reputation: ibbo's Avatar
    Try zip-tying the lever to the bars over night.This will force any last bubbles of air up into the lever reservoir and out of the system.If the brakes are still squidgy then bleed again.Avids can be a ***** to bleed but once done they're good.
    If all this fails then it could be faulty seals/hoses.
    Did you follow Avid's directions or some garage mechanic's youtube video?
    Have you given the new pads time to bed in?
    Feb 2007
    I did the procedure in the avid instruction manual, also tried a method from youtube. I have1 ride on the new pads. I don't remember them being like this before when I changed them.
    Reputation: Shalom's Avatar
    Nov 2008
    Have you checked the seals and pistons? If anything is sticking, that can cause mushiness.
    But the main cause is air, IME. Was the DOT fluid fresh?
  1. Juicy 5 mushy lever
    By robinta in forum Brake Time
    Last Post: 06-28-2009, 07:50 AM
  2. Bleeding Avid Juicy Brakes without Bleed Kit?
    By castafly in forum Brake Time
    Last Post: 02-23-2009, 10:29 PM
  3. Mushy feeling in my Avid Juicy 5
    By seis66 in forum Brake Time
    Last Post: 08-20-2007, 09:49 PM
  4. Bleeding Juicy brakes - fluid NOT going back up
    By ryan123 in forum Brake Time
    Last Post: 04-17-2007, 11:42 AM
  5. Bleeding Juicy brakes ?
    By keen in forum Brake Time
    Last Post: 12-23-2005, 09:08 PM
