Results 1 to 58 of 58
    jagwire hyflow hydro issues??? new brake fluid? or lines?
    anyone else have problems with these lines? my brakes were fine, very hard, and braked well.... no squishyness.....
    found the silver braided jagwire hyflow lines and switched out the lines and used some dot3-4 from the auto store and now i cant get
    the damn things to stop anymore....
    ive since bleed the brakes about 5 times and still .... same result.... i havent found a bottle of the original avid brake fluid to test that out....
    any ideas? basically new brakes.....
    Dec 2009
    you are not getting all the air out. Also I believe avids all use DOT 5.1
    Never trust a fart
    Reputation: frdfandc's Avatar
    Could be a couple of things.
    Air in system - Did you use the Avid proceedure? Did you use new compression fittings?
    Contaminated brake pads. Brake fluid on the pads. Need to replace if this is the case.
    You can use the DOT 3-4, Its compatible with DOT 5.1, but DOT 5.1 has a higher boiling point than DOT 3-4.
    thanks....
    yep... followed it exactly.... thanks, thats what i thought about the fluid... just wasnt positive.... i live in fla so i dont use the brakes as much.... not like im going down a mountain or anything. at least thats what i ve read about the boiling pt being an issue...
    any tips or tricks to getting the air out besides what avid has on youtube?
    just to add...
    i want them stiff as hell... i always give brand new bikes a touch test in the shop...
    i squeeze the brakes and pluck the spokes.... and new brakes are stiff....
    how do you get them like that?
    nevermind....
    im a ra-tard of the highest order.... dont ask me how.... but i fixed it..
    after i re-bled again, i took the caliper off the bike and squeezed the lever until the pads almost touched.... than i took my red spacer and pushed the pads apart just a little and now the lever is solid... no squish.... doesnt make sense to me and it probably will get squishy tomorrow when i ride but it works for now...
    thanks...
    Reputation: mojobeer's Avatar
    What do you think of the housings?
    Do they make a difference?
    Thanks.
    And if you want them stiff, turn the pad contact adjust all the way in (opposite of bleed instructions) and add a few drops of DOT 5.1 in the lever bleed screw. You wont have to re bleed them. I do this after the pads start to wear and the pad contact adjust no longer dials out enough for my liking.
    May 2010
    Here are my concerns with Hyflow hoses.
    First of all they suck. I installed a set on my saint brakes and let me tell you just one thing -----> Expansion.
    As soon as you hit the brakes hard the hose will expand and make you loose tons of braking power.
    They where made to look good at the sacrifice of braking good.
    Needless to say that after a ride outside i came back home took them off and trashed them.
    Vince
    Reputation: wilsonblur's Avatar
    Quote Originally Posted by nicolicious
    Its the Jagwire lines. I just switched mine to Jagwire's and hate what they've done to my brakes. Horrible spongy feel all the time no matter how many times I bleed them. They suck.
    Narrow is the path to life, few are those who find it.
    Old school BMXer
    Reputation: Blaster1200's Avatar
    Quote Originally Posted by wilsonblur
    I have a few bikes with Shimano XT brakes. One with Shimano line, one with Goodridge line, and one with Jagwire line. They all feel the same.
    Oh, and it doesn't matter how many times you bleed the brakes; it only takes one time of doing it right.
    May the air be filled with tires!
    May 2010
    These hoses suck. It is not the bleeding it is the expansion ! Grab the hose and brake hard with your other hand....
    Dont say you dont feel it. Now put back your original hoses ..... Ohhhh it's gone...
    Hyflow suck ass
    have to also disagree.
    I run Shiman XT`s, with the jagwire and they have always felt solid.No isues at all.
    Quote Originally Posted by Blaster1200
    You're being a little presumptuous that I didn't do it right. I am competent enough to know its not my bleeding that's the issue. I've repeatedly bled these same brakes with the stock lines until they were perfect with no spongy feeling, power and great lever feel. The same with my Hopes, Avids, and my brothers Hayes. At one point I figured it had to be me so I took it to my LBS. The wrench there is really good. He bled them four more times and came to the same conclusion that the hose was expanding. They were driving him crazy. He said to ditch the lines or go back to stock or something better. When you grab the lever you can feel the initial pad contact, when you apply more pressure you can see the hose expand from beginning to end. Its the lines not the mechanic/s.
    Your post may apply to some people who don't have experience bleeding brakes correctly, but that's not the case here. Some people can't tell the difference or don't care between a brake that set up properly and one that's not. Maybe you don't care or can't tell I am amazed how many of my buddy's bikes I get on and hate the way their brakes feel. There are also a couple of my buddy's whose bikes have brakes I love and its because they know the difference.
    Quote Originally Posted by kfother
    I noticed both of you who like the Jagwires are running XT brakes which use mineral oil. It could be an issue with certain brake/fluid compatibility. DOT 4 and other DOT fluids are better and capable of pushing a higher pressure through the lines than mineral oil. There's a night a day difference. Both brakes lack any real stopping power. I have Formula K24's which got the silly MTBR star thingy so its not the brakes. I bled the previous set up and the current one with a mechanic in between and the only difference is the lines. I can see the line expand at all the zipties. Its the lines because the stock lines never had this issue.
    Glad you guys like them, I'll never own another set. We have 3 mile downhills and really steep techy stuff in CO. I wouldn't trust the performance of these on anything I ride. I just got a set of Hope stainless steel braided to replace these. I ran those for 9 years on my Hope's without issue and I bled them every year.
    Sorry, what? How can one fluid be capable of pushing higher pressure than another?
    May 2010
    I had Jagwire hoses on my Saints with mineral oil. They where expanding like crazy. It took 5 min to take them off and put back my original Shimano hoses.
    The Difference is so obvious.
    NOW is there a revised Jagwire hose out there that dosent suck ? Maybe.
    But the white ones i purchased last year on jensonusa.com are in the garbage and they never went close to the trails. They looked good that's it.
    Quote Originally Posted by slider32
    Mineral oil is not as capable of a hydraulic fluid as DOT otherwise as posted by another user on MTBR it would be in car brakes. I don't know this for sure but I don't think you can generate as many PSI's with mineral oil. It does have other benefits though. This is about those lousy Jagwire lines so lets not get side tracked.
    Quote Originally Posted by Steel Freak
    If Mineral oil were nearly as good It too would have a DOT rating and be put into Cars, Trucks, Motorcycles etc. The seals in brake calipers and Master Cyl's are products of very evolved technology. They have those rubber compounds down and the boiling point is also a significant factor in the equation.
    If you have ever taken any courses in Automotive technology, or MMI Motor cycle mechanics Institute you would not even consider Mineral Oil as an option but a Marketing Scam aimed at Liberal Environmental People which make up a large percentage of our cycling Community.
    My Credentials are Mercedes Benz Master Diagnostic Technician, Nissan Certified Technician, ASE Brakes and suspension certified, and a Certificate of Completion from Pasadena City College Automotive Program 1994.
    SF
    Singletrack Addict!!!
    Reputation: Relayden's Avatar
    Jun 2005
    Installed on my wife's XTR, they expand, but she does not feel the difference....
    The world needs a huge socio-economic change...be it. We all need to ride more....
    Never trust a fart
    The difference between DOT brake fluid and mineral oil has nothing to do with PSI. I can generate the same amount of psi with water as DOT brake fluid in a sealed system. Fluid does not compress, regardless of the fluid. You could use iced tea in your brake system, regarding pressure.
    The difference is in freeze point/boiling point and a few other specifications.. DOT brake fluid is required to attain a really low freezing point, so that brake systems can work properly in sub zero temperatures. Mineral oil does not have a freeze point as low as DOT brake fluid.
    Another reason for the use of DOT brake fluid and mineral oil is the boiling point. A brake system can generate quite a bit of heat. Water boils at 212 degrees F. DOT 4 brake fluid has a boiling point of 445 degrees F dry, 311 degrees F wet (water in system). They also must not corrode the materials being used to make the brake systems - aluminum, magnesium, rubber, plastic, ect.
    Also they must maintain the same amount of compressability throughout a wide range of temps.
    Mineral oil works great in a bicycle brake system, but does not pass Department of Transportation (DOT)guidelines for automotive safety. Hence the requirement of DOT brake fluid
    So please do a little bit of research, before repeating "what someone else on MTBR" said.
    To add to certifications like Steel Freak.
    Ex-ASE certified in six out of 8 categories, Dodge/Chrysler/Jeep level 2 certified tech - (level one requires Diesel)
    Quote Originally Posted by frdfandc
    I did say I could be wrong. I have no issues learning when wrong, thanks for the correction. But the point of the thread is that these lines expand reducing braking power. The stock lines are far better. Do you have anything in your 6 categories of certification to add about brake lines in the automotive world. It might be very helpful to the discussion? I know that early on in some of my older (15yrs old) cars the flexible lines between the caliper and metal lines from the master cylinder would age and deteriorate causing a spongy pedal. So I replaced them with braided steel lines and the pedal feel was much better. My understanding is that if braking force is lost in the lines there's less at the pistons. I believe that is the issue my Jagwire lines have.
    I bought a Nomad and sold my BLT2. My old lines were too short for the Nomad so I thought I'd give the Jagwires a try since they were much cheaper than the stock lines or Goodrich's. I ran Hopes for nine years with their steel braided lines and they were great none of this spongy expanding stuff. I picked up a set to replace the jagwires. At this point I could have had the Goodrich's or the Carbon Fiber weave Formula's.
    Mostly I am trying to account for how some guys like them and others simply can't stand them. I have the sterling silver version. The more lever I pull the more the line expands. Xetal is right, you can feel the lines expanding with your fingers. It be interesting to see if there was a way to measure the expansion. Would a digital micrometer work? To me that signals a great loss in power through the lines. All I know is the performance is sub par compared to the stock lines.
    Never trust a fart
    I know that Jagwire offers their brake hoses in pretty colors, but other than that, I have no experience with Jagwire aftermarket brake hoses. If they are expanding, then yes, this will cause a deterioration in braking performance. If the stock hoses made braking feel better, then why wouldn't you put them back on?
    You could probably do the micrometer method. Make sure its digital - easier to read. Would take 2 people to do properly. And I'd make several measurements in different locations to get an average.
    In the auto world, cars use rubber lines at the wheels for flexibility - wheels turning, suspension actuating. Over time, they do deteriorate and braking performance can suffer.
    I prefer stainless steel braided lines (as you have mentioned) as I have had a couple of cars that I drag raced in the past.
    I guess feel all comes down to the end user on how they like the feel. There is a boat floating for everyone.
    The stock lines were on a small BLT with a 140mm fork, My new Nomad is a Medium with a 160mm fork. The stock lines are inches too short in the rear. So I can't go back only forward with new Hope steel braided lines front and rear.
    So here's a little update. I wrote to Jagwire and asked what they could do about their poorly performing lines. Here's what they said.
    Hi Mark,
    Sorry for the hassle. *I will send you new and improved hose straight away. *For some reason certain systems are having this issue. *The functionality of the brake while riding is not a problem but there is a spongy feel. *What color hose do you have and what is your address. *I will get you the new hose right away.
    Thank you,
    MacLayne
    Jagwire USA
    So as some of us had noted there is an issue with some Jagwire lines according to their own CS. It is a good thing that they would send me a new set. If you want them I'll make you a deal. Also I bought Hope stainless steel braided lines by Goodridge and there's no comparison. No spongy feel and the power has returned as well as great lever feel.
    Never enough time to ride
    Reputation: squish's Avatar
    I had the squishy line issue with a set of Hyflows on my Oros. Got in touch with Jagwire and they said the same thing and sent me a new set of lines. Work perfectly now, nice firm lever feel just the way they should be. The line also feels noticeably stiffer in your hand, so there was definitely something screwy with the old stuff.
    happy trails...
    squish
    Get out and ride!
    Reputation: client_9's Avatar
    e x p a n s i o n
    I'm so glad I found this thread.
    Been pulling my hair out as to why my rear Elixir feels so squishy.
    Probably bled the rear brake 6 times!
    I just talked to Tanner @ Jagwire and he confirmed that the Elixir causes the HyFlow hoses to expand under pressure. The Elixirs push a lot of fluid.
    They are sending me an improved (reinforced?) kit.
    I'll report back.
    Quote Originally Posted by squish
    happy trails...
    squish
    So is the replacement hose reinforced? visually thicker?
    Were you having issues w/ both front and rear brakes?
    thanks.
    There is no visible difference between the two line types that I noticed outside the printing on the outside of the line. They do however feel noticeably stiffer. Both brakes for me were quite a bit mushy than they should have been, the new lines were a huge difference.
    happy trails...
    squish
    Get out and ride!
    May 2010
    Yup yup same here. One e-mail and my replacements hoses where in the mail
    I am very impressed by the effectiveness of their customer service !
    Lets hope the replacements are not FAIL stuff like the previous set hehe
    Edit: the email address is info@jagwireusa.com not cs... Sorry, 'bout that!
    Client_9, Squish is right, we made a running change to the construction of our HyFlow hose, the intent of which is to improve lever feel. The previous version met our engineering benchmarks, but as we’ve learned, it fell a bit flat on some high-volume systems on the trial. Therefore, we made a change.
    With the revision the hose won’t look different, inside or out; it’s still a Kevlar weave around a Teflon coated liner. The change is to the construction of the liner material and, as squish noted, it is slightly stiffer now. But more importantly, it should feel crisper.
    So, if you are running our hose and are unhappy with the performance, please shoot us a message at info@jagwireusa.com so we can get you squared away with some of the new stuff. Above all we truly appreciate you choosing Jagwire!
    Cheers,
    James
    Jagwire USA
    Hey Jagwire,
    Thanks for the fast customer service.
    I received replacement brake lines a few days after my phone call. Excellent.
    I'll report back after some field testing.
    Happy to hear it. Give the new lines a shot and let us know what you think. Believe it or not, but we take feedback from users like you quite seriously.
    James | Jagwire USA | www.jagwireusa.com
    May 2010
    I am still waiting on my replacements. As soon as i get them ill post a note here on my impressions as well.
    Rock Solid !
    Quote Originally Posted by Jagwire
    Here's my field report of my Elixir CR brakes w/ the new HyFlow hoses:
    The new "TF 5.0" Jagwire HyFlow hoses not only solved my soft lever feel, my pads now retract properly!
    No more pad dragging.
    Just a small brake lever movement w/ one finger results in rock solid braking.
    I'm guessing the expansion issues w/ the previous HyFlow hoses were also contributing to my pads not retracting enough.
    Big thanks to Jagwire for the solid.
    Here's some pics:
    http://www.box.net/shared/c8tmzbtjfh
    http://www.box.net/shared/eleq2qa64n
    Haven't had much of a chance to ride on the new lines, the weather hasn't been able to make up it's mind here in Iowa. So far though the Formulas work very well, feel is very solid, power and modulation are right where I expect from my brakes.
    Jagwire, thanks for the great customer service and taking care of the issue, I don't have any issue recommending these to my customers now.
    happy trails...
    squish
    Get out and ride!
    Glad to hear it guys. We appreciate the chance you gave us to make things right.
    Hey guys, if you tried to send a message and didn't hear back from us it's because I fat fingered the e-mail address -- it should be info@jagwireusa.com.
    If you sent a message to the cs address in the last couple of days, please forward it on to info and we'll get you squared away!
    SI3
    SI3 is offline
    Caution;  Merge;  Workers Ahead!
    Hi, just a quick question... How would I know if I am getting the newly designed lines, rather than the old designs? Would I be getting the new ones if I purchased it from amazon.com? This would help a lot and save me a lot of time of trying it out and then finding out it's not the one (which then I would have to contact you). Thanks.
    Good question. Again, look for the "TF" marking on the hose. Everything in our distribution network now is the new construction, so if you order from your local bike shop you'll get the new hose. I can't speak to what you will get from Amazon.
    Thanks again for supporting Jagwire!
    ballbuster
    Reputation: pimpbot's Avatar
    Oh, hose upgraded? Good to know. That is frickin' awesome!
    I got two sets on my bikes, and both are squishy at the levers, and I know i got a good bleed on them. Not 'lever to the bar' squishy, but not as solid as the stock Shimano resin hose. Also, they kinked at the connectors super easy.
    I'll see what I have, but I'm guessing I have the older hose.
    I'll have to check out your newer hose... especially if it comes in braided silver.
    Wow... Jagwire is upgrading the hose for us?!? Top notch customer service. I've been living with it for the last 6-9 months like that, figuring all brake hose is going to feel like this unless I pony up massive fat cash for Goodrich stainless lines.
    WAWE
    Jagwire - Thanks for participating on the forums.... I just fired off an email to you guys.
    current ones at the stores in Malaysia are T 5.0 ...when will TF version arrive here ??
    ... Again, look for the "TF" marking on the hose. Everything in our distribution network now is the new construction, ...
    Hi,
    I have "TF 5.0" hoses. Are these the new version? thanks.
    SI3
    SI3 is offline
    Yes, apparently they are based on what Jagwire said from before. Do you mind if I ask you where you have purchased your hose?
    Quote Originally Posted by SI3
    Jagwire sent me this kit to replace the previous version.
    I just purchased two sets of the pink hoses as a surprise for my GF, 1 for her DS and 1 for the HT, online, and both are the T not the TF. her bikes have elixirs and I have the same issue. you can feel the hose expand.... and the braking is spongy. I am hoping Jagwire is still here. I sent them an email but haven't heard back.
    Quote Originally Posted by leet-builder View Post
    Yep, still here. We got your message yesterday and will get things sorted out via e-mail.
    OK ... So Jagwire has the best customer support ever.
    Jagwire (James) is sending out updated hoses. I realize they have no control over the retail channel.
    I just wanted to say I am a big fan of the cables, housing, seals, cable ends and the rest of the stuff Jagwire produces. All of the Jagwire products I have used are all top notch without breaking the bank so to speak.
    I am sort of a purist but when it came time to replace my road cables on my campy equipped bikes 3 years ago I went to the local "Campy" BS for new cables and housings. I use to work at the High-end bike shop here in my town and I have seen all the brands of cable and housing and I know the low quality stuff doesn't last as long as good quality cables and housing. I went to the "Campy" LBS and looked at the Jagwire and housing next to the stock campy stuff and the choice was clear.
    I took one look at the the cables and housings from Jagwire and it was clear that they are superior in every way and less expensive at the same time .. I may never buy campy for road cable replacement again.
    I have since begun to use only Jagwire for all my cable replacement needs road and mountain. I really love the sealing options Jagwire has for the ripcord line of their cable replacement. My hard tail cables have never been smoother and lasted so long in dry,wet and muddy conditions.
    Props for such personal and quick customer service ... rare in today's world.
    That is very good said.
    I have Jagwire cables on my drivetrain and brakes in my own bike and my girlfriends.
    And on the second bike for me, I want to install the Jagwire cables as well - but the new version as now I have two bikes with the same brakes and different hoses, I do feel the difference very clearly.
    Best regards
    Lukasz
    Oct 2010
    Cheers for this thread. I couldn't figure out why the juicy 3's on my new bike didn't feel as firm as the juicy 3's on my old bike. It's becuz I used the fancy color Jagwire Hyflow! What a colossal waste of money!
    Aug 2010
    Kudos to Jagwire for an excellent quality assurance response. I hope my new replacement set is on its way very soon.
    Another three cheers for Jagwire and a special one to James who advised the Taiwanese side to rush a replacement for me via Federal Express. Looking forward to my first endo!
    Propr
    Reputation: Lowball's Avatar
    Quote Originally Posted by wilsonblur View Post
    Thank you,
    MacLayne
    Jagwire USA
    I know this thread is a couple of months old but I also wanted to say big ups to MacLayne and Jagwire USA for the awesome customer service. They took care of me on a separate issue but its great to know that if a customer is not completely satisfied with anything they will take care of you with a quickness
    I have hyflow's on two of my bikes, one with Formula R1's and the other with older Juicy 7's. The bike with the R1/hyflow combo are awesome and the ones on the Juicy7's are a bit on the spongy side, but they were only bled during install and I haven't tried to do it again. They work and stop just fine but just a little spongy...so not sure if it's cable or bleed issue seeing as how the cables are only about two to three months old. And it could just be that I'm comparing them to the R1's which are far superior.
    10 TransAM SS
    S-Works M2
    Nomad3cc xx1 - Sold
    Hightower LT - in progress
    Nov 2008
    Hoping I can get an answer on this post. I'm trying to install the Hylfow hose with xt quick fit kit. I'm running XT levers, XT rear caliper, and saint front caliper. Does anyone know if the xt quick fit kit work on my saint caliper. Do I have to get a separate quick fit kit for the saint?
    Quote Originally Posted by mmanuel09 View Post
    You'll be having a problem because the Saint and Deore XT calipers uses different fittings at the caliper side. The lever side is identical but the Saint's banjo is a round side entry type whereas the Deore XT's is an inline entry type. You can see the differences in Jagwire's website.
    jagwireusa.com/index.php/products/v/hyflow_quick-fit_adaptor_kits
    Dec 2009
    Top customer service
    Hi all,
    I live outside US, but I got some Hyflow kits from a US web bikestore. I had the same spongy problem and I decided to contact Jagwire. Wow, what a customer service! MacLayne and Jagwire USA establishes a high new standard in customer service.
    Thanks Mac and Jagwire!
    Jagwire, what fittings work on the older XTR 965 calipers? The are the older banjo bolt style. I assume the banjo bolt a fitting from 2012 will fit my 2006 calipers.
    I love the gold colored hydro line BTW. 1st class.
    I looked through your documents on line and at the LBS to no avail. There isn't any mention of the XTR 965 calipers in the literature.
    Happy to hear you like the Gold Medal color.
    As for the brake compatibility, the short answer is that we haven't designed a fitting specifically for the banjo-style M965 brakes.
