Issues with >160mm rotor on a QR fork?
Sorry, guys, tried using search but couldn't find anything...
Any issues with using anything bigger than a 6 inch rotor on a QR fork? Are there differences for this application in terms of post compared to IS mount?
Appreciate any feedback, thanks all!
squish is good
The caliper mount shouldn't have a huge impact on rotor. The angle of the axle dropouts is more important. Vertical dropouts are more liable to result in the axle being yanked out as opposed to more horizontal dropouts. IME 7" rotors are usually okay on newer forks but 8" is probably a bad idea.
It really depends on the fork. Manufacturers set max rotor size that are usually available on their website. Example RS doesn't recommend larger than 185mm on the SID WC, but you could put a 210 on a Recon.
- You may not post replies
- You may not edit your posts
Forum Rules
