Results 1 to 8 of 8
    IRD dual banger adjustment
    Okay, so heres my issue.... (cross posted at bike forums, sorry if its a repeat for ya)
    Have a IRD dual banger mech disk on front. Rotor is not bent, and pads are semi new (nery little wear.) For the life of me I cannot get it adjusted so its not rubbing. Its either too loose when its not rubbing, or rubs like crap when it works as I'd like it too. I like my front brake to be very touchy. Here is how I have adjusted them:
    1. Loosen slack from cable, bottom out both barrel adjusters
    2. Loosen mounting bolts
    3. By hand, squeeze caliper tight, and tighten bolts, alternating between bolts 1/8 turn at a time till snug
    4. Let go hand and remove slack from cable, making sure caliper arm doesn't move.
    Still rubs. Wheel locks up like I want it to, but can still hear it rub. There are no tight spots when I spin the wheel, so I know the rotor is not bent, and the wheel is centered in the dropouts. (must add this is a QR wheel.) This is how the IRD manual and website says to adjust them. I have also tried the directions on the park site for adjusting Avid mech brakes, keeping in mind that when adjusting the pad adjusting knobs, that both pads move and the gap needs to be the same, not the inner gab larger. Same thing... I have also adjusted the way I would if the outer pad was fixed, as in avid brakes.
    Any suggestions. I have been patient, as I know its a art to get these adjusted correctly. I am starting to think its how tight I like the brakes to be. But that shouldn't make a difference. Thanks in advance for any input.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Is it dragging excessively to where it is slowing the wheel?
    Formotion Products
    http://www.formot
    Yeah, very little, If I spin it fast, it takes a while, but its not normal slowing. If I spin it slow, it stops right away
    Jan 2005
    Try working the pad adjust screw.
    Adjusting Pad-to-Rotor Gap:
    There is 3mm Allen head adjuster within the head of the
    larger 5mm Allen bolt in the center of the caliper. DON’T
    EVER turn the head of this exterior 5mm Allen bolt.
    The 3mm bolt adjusts the OUTBOARD pad. Turn the
    adjuster clockwise to move the pad closer to the rotor. Turn
    it counter clockwise to move the pad further away from the
    rotor.
    Adjust the gap between rotor and INBOARD pad with a
    5mm hex key on the other side of the brake. Turn the bolt
    clockwise to move the pad closer to the rotor. Turn it
    counter clockwise to move the pad away from the rotor.
    Inside and outside pads should both be about 1mm from
    the rotor (EQUIDISTANT— this is different from other
    cable disc brakes). Excessive pad distance to the rotor will
    affect brake lever throw (how far it needs to be pulled to
    engage the brake) and also how far the brake actuating arm
    moves. You don’t want the arm moving too far. (See Fig. 5)
    Formotion Products
    http://www.formot
    ^^^ did that. Still a no go. Well, with a 1 -1 1/2mm gap its quite, but then they feel sloppy. Not as tight as I like. Never had issues with my old Avid brakes. Is this just the nature of the dual bangers?
    Jan 2005
    Quote Originally Posted by jmadams13
    I have never worked with the IRD brakes so i'm going off their setup instructions and what I have done with other mechanical brakes. They also mention centering the caliper with shims, is your caliper centered? Wonder if your getting flex or give from something. Cable housing compressing, brake lever and or holder flexing. Last resort contact IRD and see if they have any secret tricks they dont publish.
    http://www.interlocracing.com/faq_tech.html
    Formotion Products
    http://www.formot
    IRD made two versions of this - direct post mount (like avids) and I.S. mount (like some, but not all, Hopes)
    which version are you working with?
    (i have an IRD Dual Banger in post mount and numerous BB7's - all the versions i think)
    Dec 2004
    it took me quite a while to get mine set up with the shims. i ended up making my own to get them perfect, then set the cable slack, then adjust each side pad. i love these. i've been using them a little over 2 years, and still, are awesome.
